Need some Help CMP C5 missing part
Old 09-10-2010, 11:57 PM
RaleighSS
RaleighSS's Avatar
Default Need some Help CMP C5 missing part
Got to CMP and found that I am missing one of the bolts that hold my capiler bracket to the spindle is missing these are not the bolts that hold the capiler to the bracket and could toque down to 100# Let me know if you can help
Paul 919 426 1551 / Chris 512-699-9013
Old 09-11-2010, 12:13 AM
sperkins
sperkins's Avatar
There are 3 Ace Hardware's close by:
In Camden - 914 West Dekalb Street, Camden - (803) 432-4219
In Lancaster - 714 South Market Street, Lancaster - (803) 283-8464
In Lancaster - 557 Lancaster Bypass East, Lancaster - (803) 285-9436
Most Ace's have the best bolt bins around. If you can get over there, I'm pretty sure what you need is a M14x2.00x35mm bolt. Or pull one from the car and take it with you.
Old 09-11-2010, 07:48 AM
beerkat
Support Corvetteforum!
beerkat's Avatar
I just picked one up at a NAPA. Not for a vette but the same problem.
To Need some Help CMP C5 missing part
Quick Reply: Need some Help CMP C5 missing part
