Exactly what is the point in running longer wheel studs and open lug nuts?
Old 09-13-2010, 08:21 PM
Rob 93ZR-1
Rob 93ZR-1's Avatar
Location: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Exactly what is the point in running longer wheel studs and open lug nuts?
I see guys with track cars all have that setup even running stock looking wheels? Is there a benefit like making it easier to change from street tires to slicks or ???
Thanks in advance.
Old 09-13-2010, 08:29 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Closed lugnuts can get packed full of crud and the stud might bottom on the crud and not seat on the wheel. Longer studs allow the use of wheel spacers which some setups require for clearance.
Old 09-13-2010, 09:16 PM
AU N EGL
AU N EGL's Avatar
plus aluminum lug nut beauty covers can get crushed or corners stripped with put on in a hurry.
the Studs are ARP hardened studs and the open ended lug nuts are also hardened.
use of spacers and yes easier to change. Plus being $1.50 or so each vs $5.00 each
Old 09-13-2010, 10:22 PM
CHJ In Virginia
CHJ In Virginia's Avatar
The studs are manufactured by ARP and are of much harder material than the stock studs. The shortest length is 1/2" longer than a stock stud so you can not use stock lugnuts. Most folks also use hardened lugs for safety purposes. They do allow the use of spacers so offset can be adjusted for clearance around big brake calipers or to allow the use of wheels that do not have enough offset.
Old 09-14-2010, 09:15 AM
DonF
DonF's Avatar
Interesting, I didn't figure that out either.
ScaryFast
ScaryFast's Avatar
It's also easier to locate the wheel on the longer stud, convenient for in pit service. And most importantly, longer studs mean much more thread for loose lug nuts to travel along before coming off and allowing the wheel to do the same.
Old 09-14-2010, 09:47 AM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Sometimes not enough time......
I got mine because they are hardened and I needed spacers at the time. I dont use spacers anymore but it is easier to put the wheel on.
Old 09-14-2010, 10:22 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Good answers guys
Randy
Old 09-14-2010, 02:53 PM
TS Motorsport
TS Motorsport's Avatar
I don't know if you guys have tried but it is very difficult to strip an ARP stud. Those things are hardened steel and indestructible.
Old 09-14-2010, 03:53 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
Maybe a rules requirement, in SCCA series. Been a while since I looked at a rule book.
Old 09-15-2010, 08:30 AM
TedDBere
TedDBere's Avatar
Once you strip or cross thread a stock one, especially on the rear, you'll understand why you want hardened ones!
Old 09-15-2010, 09:07 AM
Red5
Red5's Avatar
They don't brake off like the stock ones do. Some of us are changing wheels many times. The stock ones break off.
Old 09-15-2010, 09:39 AM
AU N EGL
AU N EGL's Avatar
Ding. that is the main reason.
Thanks Ted
Old 09-15-2010, 11:30 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
I put the ARPs in when I had my hubs off for pilot bearing install. I ended up cutting the extra 1/2" off so I could still use my fancy lugs for street. Use open ended lugs for track days.
Old 09-15-2010, 02:30 PM
Jaymz
Jaymz's Avatar
I had three of the longer GM hardened studs break off of the rear. I am now adding them to the yearly maintenance to do list.
Old 09-16-2010, 02:25 PM
Cap'n Pete
Cap'n Pete's Avatar
That pretty much says it all right there. ARP studs are the most common thing used, if/when you go away from OEM.
Old 09-16-2010, 02:36 PM
wallyman424
wallyman424's Avatar
for some reason the GM ones suck. I've had 2 break on me.
I swapped them all out for ARPs, and no problems in 3 years.
To Exactly what is the point in running longer wheel studs and open lug nuts?
Old 09-16-2010, 03:03 PM
Kubs
Kubs's Avatar
Here is a question for you all. I will need to replace hubs soon. This is only the second time I have had to and I put ARP studs in at that time. When you guys replace hubs do you press out the studs and put them in the new hubs every time or just get new studs? How many times can they go in and out before you need to replace them?
Old 09-16-2010, 03:12 PM
wallyman424
The way I see it, the ARPs are cheap enough that you should replace them.
If theyre <1year old I'd probably reuse them, but if its more id just toss them.
Old 09-16-2010, 03:28 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I take them with me to the new hubs.
It's not called Scuderia No Bucks for nothing.
Quick Reply: Exactly what is the point in running longer wheel studs and open lug nuts?
