new lsx 102 intake and nick williams 102 throttle body instal
Old 09-14-2010, 11:59 AM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
Default new lsx 102 intake and nick williams 102 throttle body instal
gained 1 ,,that's 1 horse power..lost in the mid range....that's is an expensive ONE horse power.
Johnny
Old 09-14-2010, 08:34 PM
AutobahnRacer
AutobahnRacer's Avatar
Johnny
Did you dyno tune after the equipment upgrade? I'm having my LSX102 installed this week, and next on the list (before I even see it) is the dyno . . .
Old 09-14-2010, 10:12 PM
C5ZEE06
C5ZEE06's Avatar
Johnny
how about some details ?
what intake / TB were replaced ?
what other mods you got ?
etc
Old 09-14-2010, 10:19 PM
Pumba
Support Corvetteforum!
Pumba's Avatar
I agree.
Let's have a lot more detail about the motor:
  • Displacement
  • Bore
  • Stroke
  • Compression Ratio
  • Heads
  • Camshaft Specs - lift - int duration - exh duration - Lobe Separation Angle
  • Headers - primary tube length - tube diameter
  • Fuel used
  • RPM range - 2,000 rpms to 7,500 rpms?
  • Etc.
Old 09-14-2010, 10:25 PM
doje
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old 09-14-2010, 11:02 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Johnny
Are you running a stock 85mm Maf? What size intake tract..4.00"?
Old 09-14-2010, 11:41 PM
Git Er Dun
Git Er Dun's Avatar
I know the car has a C5R motor thats fully built. I think it's a 427ci motor but not sure. Some NASCAR shop in NC built the motor I think but not positive. I looked into buying the car when it popped up for sale once and everything on the car is the best out there and I'm sure the motor is no exception.
Johnny: Glad to see that you got it running again and a new motor in it. What did it make for hp/tq?
Old 09-15-2010, 10:05 AM
racerwannabe
St. Jude Donor '06
different car and motor,,the race engine is STILL in concord{only been two years}
Ls-6 intake and throttle body replaced with fast intakeand 102..
2004 crate motor ls-6
Old 09-15-2010, 10:09 AM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
That is way too much air for a stock LS6. You would have been better off with a ported stock unit or 85mm. I am surprised you saw any kind of gain. It will help more on a built engine though.
Old 09-15-2010, 10:11 AM
racerwannabe
St. Jude Donor '06
the new plan is to build a LS-3 at 427 or so..then the extra air may be put to good use..
in the mean time..we'll have a pretty intake
Old 09-15-2010, 10:59 AM
Kubs
Kubs's Avatar
Old 09-15-2010, 11:23 AM
SIK02SS
SIK02SS's Avatar
This. The FAST 102 was designed with big cube motors in mind. Like an LS3 416 and up..
Old 09-15-2010, 11:24 AM
SIK02SS
SIK02SS's Avatar
Nice My sponsor shop CMS (board sponsor too) is building a 416 LS3 for my 2002 Camaro SS right now. It will be a very healthy car when done
Old 09-15-2010, 12:33 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
that seems to be the going rate on a stock cube car. id love to get one on my 416 and see what it would do, but even on bigger cube cars on LS1tech, the gains are not worth the 1500+ money.
Old 09-15-2010, 01:10 PM
Git Er Dun
Git Er Dun's Avatar
Oh bummer! It's already been 3 months since the dyno run and I talked to you last...so hopefully they get it done soon for you!! Good luck!
Old 09-15-2010, 01:17 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Johnny, I'd bet your being resticted by the maf or tract ahead of the TB.
Old 09-15-2010, 02:16 PM
RC45
RC45's Avatar
The LS6 Fast will not work on the LS7 heads. Different intake port shape. They have LS6 and LS7 specific versions.
On my LS7 build, the 100mm throttle body only delivered gains when paired with the 103mm MAF and a giant air filter. One day I might get around to swapping the ported LS7 intake with the 102mm FAST. I dont expect to see much ain, just hopefully fill in the upper middle of the power band a little.
To new lsx 102 intake and nick williams 102 throttle body instal
Old 09-15-2010, 02:26 PM
VGLNTE1
VGLNTE1's Avatar
even on my 416 my 85mm MAF is not pinged out...close but not. so a 346 will be just fine with one.
he just needs to add some TFS 215 heads for that intake
Old 09-15-2010, 04:39 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Oops, I thought he was running his C5R.
Old 09-15-2010, 04:57 PM
SIK02SS
SIK02SS's Avatar
what size cam do you have? i can update you when i get my numbers
Quick Reply: new lsx 102 intake and nick williams 102 throttle body instal
