305's on all 4 corners for track use?
Old 10-08-2010, 05:42 PM
maxattack
maxattack's Avatar
Default 305's on all 4 corners for track use?
Hey guys,
I am looking to do a square set up using 18" wagon wheels on my C5 for track use. I know the conventional "rules" say you should not use wider than a 285 on the stock rear wagon wheels, but has anyone used a 305 without issues? Finding matched sets of 285 or 295 r comps is not as easy as I thought it would be.
Thanks,
Brandon
Old 10-08-2010, 07:02 PM
AU N EGL
AU N EGL's Avatar
Turn off TC & AH would be advised.
I ran GY 18x25.5x11 1/2 on all four corners with out problems.
Pushed a bit in the corners until the tires were warmed 1/2 lap or so
Old 10-09-2010, 04:50 AM
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
Would 305s be an issue with the DRM air ducts??
Old 10-09-2010, 07:15 AM
AU N EGL
AU N EGL's Avatar
Only if you turn lock to lock. So dont turn Lock to lock
I run 18x305/30 on the front now, and 18x335/30 rear
Old 10-09-2010, 09:26 AM
tstar
tstar's Avatar
Yeah but you're special!!! My luck I'd crack my damn DRM ducts!
They would be track only tires so that would work... Maybe a tad smaller though, I'll have to check and see which ones are easier to get on a day to day basis in scrubs...
Thanx Tom!
Tim
Old 10-09-2010, 11:24 AM
AU N EGL
AU N EGL's Avatar
Brake ducts are like rotors, expendable every few years
Track wheels left, 18x305/30 on 18x12, and 18x335/30 on 18x13
Street wheels right 18x275/35 on 18x10 and 18x335/30 on 18x12
Old 10-09-2010, 11:25 AM
AU N EGL
AU N EGL's Avatar
Thanx Tom!
Tim
Tim
See what Joe and Phoenix Performance sells. He sell quite a few scubbs a year.
Not sure how far you are from Phoenixville
Old 10-09-2010, 03:29 PM
tstar
tstar's Avatar
Four or Five hours... Just far enough to incur a freight charge.
Thanx for the info, I'm going to check with Todd at GT Tires also.
Tim
PS I had those new Brakes really cooking last Sunday, found the limit on the Sport pads...
Old 10-10-2010, 10:17 AM
maxattack
maxattack's Avatar
Thanks guys, I think I will shoe horn those 305's on there and give it a shot.
Brandon
Old 10-10-2010, 12:26 PM
hamdog
hamdog's Avatar
Those wagon wheels are heavy. Invest in a set of used C5Z Speedlines or Alcoas. You can find them for under $400.
Old 10-10-2010, 01:01 PM
froggy47
froggy47's Avatar
I picked up some used a6 335's to try on my stock 10.5 x 18 rear rims.
Do you run a spacer to clear the tub? How thick? Thanks.
I'm on stock bolts & not lowered "all the way" in the rear. I am all the way down on the front stock bolts.
Old 10-11-2010, 08:11 AM
AU N EGL
AU N EGL's Avatar
Froggy
My street rear rims are 18x12 with the 18x335/30 Mich PS they rubbbed the inner liner out on cornering
my track rims are 18x13 and 18x335/30 hoosiers GAs Needed a 3/8" spacer and loner ARP studs to fit.
Old 10-12-2010, 11:42 AM
Gordy M
Gordy M's Avatar
You can run the 295 A6 Hoosier's on all four corners without problems, be sure to turn the TC off or at least run in competitive mode.
Old 10-12-2010, 11:44 AM
Gordy M
Gordy M's Avatar
Originally Posted by maxattack
Hey guys,
Thanks,
Brandon
I have a set of 285/295 scrubs sitting in my garage. I was always going to mount them but have not yet done them.
Old 10-12-2010, 12:16 PM
froggy47
froggy47's Avatar
Froggy
Thanks,
I am going to try squeezing the 335's on a stock (10.5) rim so will have to experiment with some spacers. I have run 315's with no spacer & they clear fine. I think a 1/4 or a 3/8 should do.
Old 10-12-2010, 01:07 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,397 Likes on 749 Posts
I've run 305s on 18" WWs for years without problems. Haven't had any problems with rubbing, but I don't usually go to the limits when parking.
And, having both a set of WWs and Z06 rims, their weight isn't that different, and the WWs are half the price.
HTH, and have a good one,
Mike
Old 10-12-2010, 06:14 PM
tstar
tstar's Avatar
Does that mean you want to sell them?
Tim
To 305's on all 4 corners for track use?
Old 10-12-2010, 07:49 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Originally Posted by froggy47
Thanks,
That's pushing it, watch out for roll.
Old 10-12-2010, 09:33 PM
Everett Ogilvie
Everett Ogilvie's Avatar
18X12 on the front, nice! - what did you have to do to fit that large wheel up front?
Old 10-13-2010, 07:21 AM
AU N EGL
AU N EGL's Avatar
-2.0* camber
and they still stick out a bit
Quick Reply: 305's on all 4 corners for track use?
