Elite C5 Tunnel Plates
Old 11-15-2010, 10:43 PM
michaelkrelina
michaelkrelina's Avatar
Default Elite C5 Tunnel Plates: are they worth it?
Are upgraded tunnel plates useful on a C5Z? Will the increased rigidity be possible to appreciate without upgraded control arm bushings.
There are two thicknesses available 1/4 and 3/8" in aluminum. Is there a much greater benefit with the thicker plate. Is it worth the extra weight?
I would appreciate your input. Thanks
Old 11-16-2010, 12:18 AM
kmagvette
kmagvette's Avatar
I added it just for the heat shielding. The 3/8" ceramic coated is very effective. My car is caged, so I really did not notice any chassis stiffening going on.
Old 11-16-2010, 12:55 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
I have the coated 3/8 but can't tell any difference in stiffness or heat reduction.
Old 11-16-2010, 08:31 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
They work for heat deflection. never noticed any faster lap times. You could probably make better gains else where with your coin.
Old 11-16-2010, 08:53 PM
michaelkrelina
Thanks for your input, everyone. It seems that the tunnel plate makes little (if any) difference to the chassis stiffness.
MK
To Elite C5 Tunnel Plates
Quick Reply: Elite C5 Tunnel Plates
