List of parts and cost to convert C5 ZO-6 to track car???
Can someone illustrate a list of necessary parts and cost to convert a C5 ZO-6 to a daily track car / street legal car leaving the engine stock?
Looknig at Accusump, shocks, wheels/tires, brakes, race seats, harnesses, (I already have the T1 sway bars with heim ends).
Also, since C5 T1 is going away what classes are still available to run and what mods are necessary/restricted.
Thanks!
Thanks!
Track car or racer? Big decision. And a huge difference in money.
Richard Newton
Vintage Motorsport Column
Richard Newton
endless question. Cage installed? In today's market cheaper to buy one built up. What coolers, what brake system, it just goes on and on. Do you want to get on track or do you want to win? Better to say what your budget is for the car. Are you running HPDE or racing? Do you have an idea on what running a race car cost even to be in the front pack?
if they run in your area, I'd look into NASA TTA. Your bars are legal, along with a few specific mods. You can trim some weight, run sticky tires etc. Would be great for DE, then run TT for a bit of competition as your driving improves.
I'm with above.....unless you have a lot of experience, just change brake fluid and hit the track!
Thanks!
Thanks!
Bill
No cage then, so a harness bar is needed = $350
Race seat/mounts and harness = $1500ish
Hans/RagePro/helmet = $1000+
Brake ducting = $350
Tires and wheels = used under $2000
accusump = I've no idea
radiator with oil cooler = $1300
tranny/diff coolers = $ 1300
short shifter (a must IMHO) = $300
new NAPA rotors = $200
Pads = whatever you do
fluids - all of them should be changed for peace of mind
Alignment and cornerweighting = $350ish
Laptimer (to measure yourself) = $100 (with bluetooth satelite receiver on Android phone) to $2000
A buttload of time to install
That's about what I went through, and still am, with my '01Z for track duty. I still want to do the T1 bars...ran out of money/wife's patience.
You could probably do it for under $5K or up to $10K, depending on your skill as an installer or what parts you really want to use (used or new). We haven't touched on shocks/springs...
As many will say, it's cheaper to buy a car already done but I like doing things myself and knowing what and how these things are done...it's also bonding time with the car...although my patience is growing thin. NO doubt, I would have been served better if I just bought a T1 car from Phoenix.
I've always found this....make your budget, then add at least 50% so you're not amazed at the total when all is said and done. The list is not that different than other cars, I usually dump at least $10K into a car during my ownership for mods/prep.
When done, you'll have a pretty fast car...dollar for dollar...one of the fastest. Then figure about $1000 a day for HPDE days (all in...gas/hotel/food/gas/and so on). Race days will be exponentially higher, or so I"m told.
Good luck and have fun, enjoy it, it's a great experience.
Be good,
TomK
The C5 in T1 might not be going away in 2013 if my proposal gets approved.......watch for the next FASTRACK for the decision. It could double the amount of time remaining for the C5 platform.
Received 8,928 Likes
Run street tires and stock wheels. Speeds will be down some but the overall cost will be lower. Speed at an HPDE doesn't matter that much since you aren't racing anybody. Getting track wheels and tires not only increases tire costs but also increases maintenance costs as wheel bearings and tie rod ends fail more often. Use the stock seat belt with the cinch feature activated and you will probably be safer than if you add a harness bar. You will have to use your legs to brace yourself when going around corners but that just gives a greater sensation of speed. The only thing I would do is add an oil cooler so the oil temp can be held down to a reasonable level. Using low performance track pads Vs the highest performance pads cuts costs since the pads cost less and the rotors last longer.
There is a tipping point where you start to do things to increase performance and once you start sliding down that hill it is tough to keep from spending a lot of money. I have seen some guys go from driving to the event in their completely stock car to showing up in an 18 wheeler with 2 track only cars and a mechanic to take care of them. Myself I went as far as harness bars, race seats, track wheels with R compound tires, BBK, race pads, larger radiator with EOC, tranny cooler and towing the car to the track on an open trailer. Thus the cost also included a tow vehicle and the trailer.
Since I got rid of the 03Z last year I have been trying to back away from that with the 08Z. Get as close to the street vehicle as possible and maybe even sell the truck and trailer.
Bill
It's a long slippery slope. None of our advice here will matter. It's like crack. Once a person decides to just try some crack there's no helping them.
I've been running the Camaro in the LeMons and Chumps series this past year. I can't believe the amount of time we spend on that car. We're not even trying to win - we just want to finish.
I started with track events a decade or so ago. I drove to the track and then drove home at the end of the day. That was really a lot of fun.
Then I went to a dedicated track car. Now I needed a trailer, a truck and a helper. Still fun - just not as much. I was spending 2 days before the event and 2 days after the event working on the car. Still ok.
Then I moved to endurance racing. I have a 5-person team and we're spending thousands of dollars a month. We're towing for two days and running up huge motel bills. This is not as much fun as it used to be.
I actually knew all of this before I started. That's the sick part. I just had to experience it though. None of our advice will help these folks here. The addiction is just too strong.
Richard Newton
Race Cars 360
Richard Newton
Race Cars 360
Richard Newton
Race Cars 360
Richard Newton
Race Cars 360
Bill
"AlohaC5" Senior Member
The C5 Z06 is a "turn key" road course car - save your money for track time and have fun! seat time... seat time... seat time... You will be faster than most of the cars you'll run with as you gain experience. If you become serious about racing (vs. track time) then a used T1 car is a very reasonable option.
