Brake Wear
Brake Wear
I'm running a stock 2004 Z06 at track days, and I noticed that my rear brake pads tend to wear twice as fast as the fronts (ie, for every front set of pads, I replace two rear sets of pads).
I run with traction control and active handling off at the track, but it seems unusual that the pads would wear this way.
Is this normal? Is it possible that maybe the rear rotors are worn in a way to go through pads more quickly? This has happened with two sets of rotors.
I had this problem initially with my car and when I figured out that the traction control was applying the rear brakes, then I started using the competitive mode (as I improved my driver skills) and then I started wearing out the fronts first. You might check to see if your TC is really off. I don't know how to check for that but in the Comp mode you should not have this problem.
What kind of pads are you using front and back? The rotors should not be a cause
depending on your driving style and suspension/tire setup, C5 AH mode could put excessive wear on either front or rear pads, but rear is more common.
if you have everything off, this kind of wear is pretty unusual assuming you have same type of pad in the rear vs front and the pads are stock shape/thickness
i suppose it could happen if you have "more traction" in your rear tire somehow under braking, causing dynamic bias to shift to the back, which would be pretty unusual, especially if it persists for several days.
For me, I get one weekend out of a set of fronts, maybe 3 weekends out of a set of rears... that is a factor of 6 different than you.
when I ran hawk HPS or HP+ I got one day out of the front pads
with Wilwood H or PFC-01s I get three weekends out of a front set and 5 weekends out of the rear set
I tried some CL RC6 pads for one weekend, I'll get 1.5 or 2.0 weekends out of them.... I agree with you on the H pads, they last a long time.
I miss read it and was wondering why he ask the question. Now I see he is wearing the backs 2 x as fast. Some is wrong for sure.
At the track both active handling and traction control are off.
I'm running stock pads and rotors, and have been through two sets of tires (Nitto 05, and Firestone wide ovals) since noticing this on a a couple sets of rotors, and a few sets of pads.
I'm wondering if maybe there is an issue with traction control during street driving, but I haven't really noticed any unusual feeling.
I'll slap on some new rotors and pads, and see if it happens again.
For a C5Z - Press and release once to turn of AH/TC. This illuminates the amber light on dash. Corresponding message in the DIC.
Press and hold for 5 seconds to put AH in Competitive Driving mode - AH is less intrusive, but still active, TC is off. No light on dash. Corresponding message in the DIC.
if you are running stock pads you may be overheating them, in which case longevity becomes somewhat unpredictable.
start by putting some temperature paint on the rotors to see how hot things get, you can pick a pad based on that.
Sorry, I assumed a 2006 C6 wasn't that much different from the '04 Z. In my C6, press once is TC Off. Press again is Comp Mode. Press again and you're back to full nannies. Press & hold for 5 seconds is All Off. Sorry if I added confusion.
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
I might do that someday, but right now I'm still hangin' on trying to keep everything stock!
