Who runs a HANS with a 6-point harness, seat, and harness bar in their C5's?
I am getting ready to purchase and install a Cobra Suzuka GT seat, 6 point harness, and BK harness bar in my C5Z. I am doing this with the intention of using a HANS. My only concern is that the belts may be at a slight upward angle instead of level or slightly lower than my shoulders. I wont know until the install is complete.
I figure that I am not the only one that may be in this situation, so who else out there runs a similar setup? Any issues, words of advice?
Thanks in advance.
Thanks in advance.
i have a Cobra Suzuka GT, TeamTech RamPac 6pt, Hardbar seat mount, Brey-Krause harness bar, and a HANS Pro Model 20, and an EB C5z.
Setup works great. I do not have the sliding tethers on my HANS, the only time I know I have it on is when I try to look in the passenger side mirror backing up in the paddock. Get the sliding tethers.
Otherwise, I am not sure what the exact dimension is for the relative height of the shoulder belts to the mounting point. It will depend on how high you mount your seat and with what type of brackets...
http://hardbarusa.com/hardbar/produc...products_id=45
The seat brackets come with a plethora of holes. Adjust the side plates to give you the right distance from the wheel/pedals, seat height for head clearance, and seat angle.
Then, use 4 of the unused mounting holes to mount the anchor end of your lap belts and sub belts.
I bought mine used, so I don't know exactly what hardware it comes with. From the picture on the website, it shows hardware for the bracket and the bracket to floor pan connection. You may have to supply the bolts for the seat (4) and for the belts (4). I used nylocs on all the fasteners...
if you need some extra height to get the angle right, cannot move the seat up, and still have headroom, you can try more padding under your butt.
you could also have someone modify the harness bar or its mounts with some creative welding to get you the right angle. you can ask BK about their recommendation, I am sure they answer those questions all the time
given the research that safety equipment manufacturers put into the instructions on routing the harnesses, I think it''s a big deal.
I have a Cobra Suzuka seat, Schroth Profi-II 6h harness 6pt, Hardbar seat mount, Hardbar Harness bar, and a HANS Pro Model 20, and it's mounted in a C5 Coupe.
Your belt angle and position will be determined by how high you mount the seat. With the Hardbar harness bar you can get the extenders and it gives even more adjustability for the height of the bar.
http://hardbarusa.com/hardbar/produc...543b327057ed00
I guess I should have made it more clear in my OP, but what seat setups do people run with what harness bar, their height, and how do the belts get positioned relative to their body.
Im thinking this may be the case or close to it as right now with the stock seat my helmet has about 1/2" of clearance with the roof when I am not sitting up straight. If I straighten up in the seat my head heads the head liner.
oh I see.
I think you will be fine, sitting in a stock seat is not really a good comparison
imagine a sumo wrestler pushing you down into the seat by pressing on your shoulders and chest - that's about what your position will be with a properly tightened harness
there is usually enough adjustment in the seat mounts to get you a good angle, if it is a shop doing this, you can ask them to call you in for a trial fit (remember to bring your hans, it changes the angles) before you accept the work.
Received 8,930 Likes
I think you will be fine with the BK harness bar. It sits a lot lower than the Hardbar harness bar.
Bill
Bill
