15W-50 Mobil 1 oil....
Old 03-18-2011, 03:54 PM
Falcon
Falcon's Avatar
Default 15W-50 Mobil 1 oil....
WalMart used to have 5 quart containers for ~$24, but I can't find a Wal Mart that carries it. It appears as though they quit stocking it.
Any of you guys had any luck finding any at that price?
drivinhard
Support Corvetteforum!
drivinhard's Avatar
last I I checked, it was at wally here for that price
Old 03-18-2011, 05:33 PM
MJM
MJM's Avatar
my local walmart runs out of the big jugs and it takes months for them to restock.
Old 03-18-2011, 05:41 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
BJ's got out of all automotive supplies.
Old 03-18-2011, 06:54 PM
AU N EGL
AU N EGL's Avatar
Bought 6 jugs. four 5-w30 and two 15-w50 at that price.
Old 03-18-2011, 06:59 PM
sperkins
sperkins's Avatar
I picked up a couple of them at wally-world a couple of weeks ago.
Hopefully they're just out of stock.
Old 03-18-2011, 08:52 PM
Falcon
Falcon's Avatar
There were no shelf tags for the 15-50 5 quart jugs anywhere, they'd all been removed.
Old 03-18-2011, 08:57 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Its hit and miss - my Wallmart hasn't had it for 6 months
Old 03-18-2011, 10:21 PM
dvandentop
dvandentop's Avatar
**** hope mine has em next time i got
Old 03-19-2011, 08:15 AM
AU N EGL
AU N EGL's Avatar
Jody
does not Big Pine Key Adult Theme Park have more then one Wally world?
Old 03-19-2011, 09:54 AM
Rob Willis
Rob Willis's Avatar
I don't see it often at all anymore.
Used to ALWAYs be in stock.
Old 03-19-2011, 09:58 AM
Falcon
Falcon's Avatar
Originally Posted by AU N EGL
Jody
Yep, and neither one of them (Statesville nor Moorseville) have it.
Old 03-19-2011, 11:13 AM
travisnd
travisnd's Avatar
Wally world's Supertech brand oil is basically private label M1.
Old 03-19-2011, 01:50 PM
gmccreary
gmccreary's Avatar
I couldn't find any at the closest wallyworld. I may have to venture further out in Maconga.
Old 03-19-2011, 02:28 PM
Jim 47
Jim 47's Avatar
Why don't you call Mobil at 1-800-ASK-MOBIL and ask them
wht is going on out there??
Jim
Old 03-21-2011, 08:22 PM
John Shiels
Looks like it may be gone or going to 0-50. I found it F/S on M1 website but some say it is not made any more.
Old 03-21-2011, 08:23 PM
John Shiels
Default From other thread
may be dead because I see this Edit I found it F/S in 55 gallon drums on Mobil 1 site $3065.00 found quarts for 11.50 ea
http://www.mobiloil.com/USA-English/...ing_0W-50.aspx
Mobil 1 Racing oils
High performance motorsport formulas
Product Description
Mobil 1 Racing 0W-30 and 0W-50 were developed specifically for racing engines and are not recommended for street use. These high performance, fully synthetic formulas are specially balanced for friction reduction and optimum horsepower with outstanding wear protection.
Features and Potentail Benefits
Mobil 1 Racing oils are proprietary formulations of low viscosity synthetic base oils fortified with a precisely balanced component-blended additive system featuring high levels of anti-wear and friction reducing additives. This advanced protection is engineered to help deliver optimum horsepower with outstanding wear protection. Features and potential benefits include:
* Boosted levels of anti-wear protection -- well beyond those of ordinary automotive oils -- to help protect engines even during grueling racing applications.
* Helps to maximize power output by reducing internal friction.
* Outstanding shear stability and a robust additive package to help reduce oil breakdown and help to extend engine life, even under some of the most extreme conditions.
* Compared to conventional racing oils and higher-viscosity synthetic motor oils, it provides faster flow to critical engine parts at low temperatures
* Helps to deliver exceptional high-temperature protection, even at temperatures in excess of 400 degrees F (204 C)
Mobil 1 Racing 0W-50 provides exceptional high-temperature protection in high RPM engine operation, even at temperatures up to 500°F (260°C).
Applications
Mobil 1 Racing 0W-30 and 0W-50 are recommended for a wide range of race engine applications. Note: Mobil 1 Racing 0W-30 and 0W-50 are not recommended for street use.
* Mobil 1 Racing 0W-30 and 0W-50 are recommended for a wide range of race engine applications including highly loaded flat tappet designs such as NASCAR Cup engines.
* Mobil 1 Racing 0W-30 and 0W-50 are designed for use by professional, amateur and weekend racers.
* Mobil 1 Racing oils are not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Typical Properties
Mobil 1 Racing 0W-30 0W-50
SAE Grade 0W-30 0W-50
Viscosity (ASTM D 445)
cST @ 40 ºC 63.5 100
cST @ 100 ºC 11.5 17.2
Viscosity Index 178 189
Sulfated Ash, wt% (ASTM D874) 1.3 1.3
HTHS Viscosity, mPa s at 150 ºC (ASTM D4683) 3.3 4.1
Pour Point, ºC (ASTM D97) -54 -54
Flash Point, ºC (ASTM D92) 217 221
Density at 15.6 ºC g/ml (ASTM D4052) 0.85 0.85
http://www.mobiloil.com/USA-English/...Qs.aspx#FAQs11 top of page
I've been using Mobil 1 15W-50 in my race car. How are these new oils better/different?
Mobil 1 15W-50 is a higher viscosity oil that delivers a thick oil film for protection of high performance engines. While Mobil 1 15W-50 can be used and is recommended for both street and track use, the new Mobil 1 Racing oils are not recommended for general street use where vehicles use catalytic exhaust converters. Mobil 1 Racing 0W-30 and Mobil 1 Racing 0W-50 are lower viscosity oils designed to protect the engine under high output conditions in high operating temperatures. Additionally, Mobil 1 Racing Oils offer boosted levels of anti-wear protection (nominal zinc level of 1850 ppm) for extra engine protection in highly loaded flat tappet engine designs like those used in the NASCAR Sprint Cup series.
To 15W-50 Mobil 1 oil....
Old 03-21-2011, 08:42 PM
drivinhard
drivinhard's Avatar
couldn't find it tonight at my usual location either
I talked to an M1 rep at PRI, and they said the 0w-30 and 0w-50 new racing oils are what I should use
Old 03-21-2011, 08:59 PM
mfquinn
mfquinn's Avatar
I just picked up some at my local Wal Mart. It is hit and miss for most things at that store
Old 03-22-2011, 01:53 PM
Rob Willis
Rob Willis's Avatar
0w-50 racing M1 is what the C6R GT2s are using
Quick Reply: 15W-50 Mobil 1 oil....
