C5 T1 sway bar ?
Old 06-14-2011, 09:59 AM
ooldguy
ooldguy's Avatar
Default C5 T1 sway bar ?
Are the adjustable end link's needed if the car isn't lowered ?
Needed if the car is lowered ?
How would you keep the adjustable end links " clean " ?
How are they maintained ?
thanks
Robert Dudek
Old 06-14-2011, 10:04 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
you don't have to have them but if you want to corner weight the car or even set them with zero preload they are better. Just spritz them with some lube from time to time.
Old 06-14-2011, 04:51 PM
froggy47
froggy47's Avatar
You are liable to have some clunking noise with adj links, I am on my 3rd brand & all clunk.
To C5 T1 sway bar ?
Quick Reply: C5 T1 sway bar ?
