Mocal engine oil adapter...built in thermostat
Old 07-11-2011, 10:49 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Mocal engine oil adapter...built in thermostat
I just recently saw this. Obviously it will fit and LS engine, but has anyone used it in a Vette? With the temp sender sticking out the top, and very little room to negotiate oil lines, I just wonder how well it works out. Even the DRM unit (very nice piece) is difficult to install with the engine in the car
http://www.racerpartswholesale.com/p...Oil_Thermostat
Old 07-11-2011, 11:04 AM
SIK02SS
SIK02SS's Avatar
http://www.ls1tech.com/forums/genera...e-install.html
post #2, the fittings hit the block and hangs too low on a 4th gen fbody..
SIK02SS
SIK02SS's Avatar
I'm still tempted to get one and see for myself though on my '02 Camaro..
Old 07-11-2011, 02:58 PM
2000BSME
2000BSME's Avatar
Why worry about it? After driving for years with no stat in my cooler, I see no need.
Old 07-11-2011, 04:21 PM
davidfarmer
I have Customer interested in the thermostat, plus it is cheaper than many of the adapters
Old 07-12-2011, 10:42 PM
2002rich
2002rich's Avatar
I tried it last year and sure enough it does not work
Old 07-12-2011, 11:28 PM
RX-Ben
RX-Ben's Avatar
Has anyone called Mocal about this? They are a pretty solid company.
Old 07-13-2011, 12:30 AM
2002rich
2002rich's Avatar
Yes I have and they explained to me that they can't design it to work with all the model year cars. For me it wouldn't clear my headers and even tried different type fittings, *90 banjo and still no luck. In the end, I used their standard Mocal *200 degree thermostat. All is good
Old 07-13-2011, 06:39 AM
sothpaw2
sothpaw2's Avatar
Agree. Without a stat, my stand alone cooler gets to 190F on the street with light highway driving because I put a little home-made cover (header wrap, cardboard, styrofoam) over it. Even at the end of November, it still hits 180.
Unless you want to drive the car when it's below 30-40 outside a lot in the winter, then I don't see the need. The cover is easily removed...I do it at the track or in the garage before I leave. You don't have to jack the car up or anything to get the cover off...all you need is a pair of scissors to cut the zip tie.
To Mocal engine oil adapter...built in thermostat
Quick Reply: Mocal engine oil adapter...built in thermostat
