How accurate are higher pressure tire gauges at low pressures?
I'm looking to get a nice tire gauge as I'm tired of the inconsistencies and short life spans of the $20-50 gauges. However, I'd like to get one gauge to meet all my requirements. The primary use case is of course my C5Z race car, so accuracy in the 30-40psi is key. However, it'd be nice to be able to use it on my sand rail as well, so accuracy in the 10-15psi range is nice. Sand is forgiving though, so a few percent off between tires would never be noticeable. Finally, my truck I run about 65psi in the tires, and around 80 in the airbags when towing and I'd like a gauge I can use for those too.
This is one of the few I've found that can handle enough pressure for all the jobs: http://www.longacreracing.com/catalo...d=1392&catid=8 but I wonder how accurate it'll be at lower readings?
-TJ
-TJ
Received 8,929 Likes
I was looking at air gauges just a while ago. Not sure which web page it was on now but they recommended buying a gauge high enough that most of your measurements are in the middle of the range. That is where the gauge is the most accurate. Also get as large a dial as possible because it makes the readings easier to see (improves your accuracy) and since you get larger and better internal gears it maintains a calibration for a longer time period. Get liquid filled because that reduces the shock load on the gears inside when you apply air. Other than that I think you will find all gauges are pretty much the same accuracy. If a gauge hasn't been calibrated don't count on it being accurate and if it has been calibrated it probably has to be calibrated on a 6 month schedule to maintain its accuracy.
Update: Found the link to a guide on how to select a precision gauge:
http://www.soloperformance.com/asset...oose_gauge.htm
Personally, I have been using a 2 inch gauge that I bought from Summit Racing about 15 years ago with no issues.
Bill
Bill
WAT? I've had cheap gages and expensive ones, and the lifespan hasn't varied at all between them. I use a walmart cheapo and the accuracy is great. You are thinking about this way too much.
One of my columns last year in Vintage Motorsport magazine dealt with tire pressure gauges.
The main thing to remember is to use the same gauge every time you check your tires and never ever use that gauge on the tow truck How you treat, and use, your gauge is much more important than the brand of the gauge.
Richard Newton
My Facebook Page
Richard Newton
My Facebook Page
