Lightest, affordable rotors for 06 Z51
Old 07-24-2011, 01:57 PM
Neumonic2002
Neumonic2002's Avatar
St. Jude Donor '09-'10
Default Lightest, affordable rotors for 06 Z51
Pads are finally to the point that it is about time to do my brakes, already have a set of new GM pads just need to see if I can afford to put a nice set of rotors on or if I am going to turn my stock rotors.
I do not road race, used to drag race but Gateway closed at the end of last season.
wouldn't mind saving a little weight if possible, I run the car pretty well and do several back-road type cruises with friends but thats about it.
Thanks for any feedback/recommendations.
John in STL
Old 07-25-2011, 03:40 AM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
I have these on my 07 Z51 DD, they are very lite and last a long time. I have over 65,000 miles on my set so far. I am not sure what affordable may be to you, but I just wanted to share the info.
http://shop.performanceafx.com/C6-Z51-Corvette_c15.htm
Old 07-25-2011, 07:17 PM
Neumonic2002
I have read about them before, the reviews were very good as well. Did you purchase yours from the vendor the link went to?
Thanks for your feedback!
Old 07-25-2011, 07:54 PM
torque*is*cheap
torque*is*cheap's Avatar
Check out rockauto.com
They have OEM cross-drilled Z51 rotors for about $80-$100 apiece.
For just aggressive road driving, I doubt you could sense lighter 2-piece rotors, even if they saved 5 lb. per corner. The wheel/tire alone is roughly 50 lb.
Old 07-25-2011, 08:30 PM
Gering
Tolero Apto Victum
Gering's Avatar
I had a shop order them for me, but you can contact this member for purchase and info. His user name is Vector Vette. Here is a good thread for info http://forums.corvetteforum.com/c6-z...post1578226843
Old 07-27-2011, 10:30 PM
Neumonic2002
I was just on rockauto today getting parts for a friend, very good pricing.
Thanks for the info guys!!
To Lightest, affordable rotors for 06 Z51
Quick Reply: Lightest, affordable rotors for 06 Z51
