question for those of you with laid down radiators
Old 09-28-2011, 06:11 PM
wallyman424
wallyman424's Avatar
Default question for those of you with laid down radiators
I've got my mounting of the radiator sorted, just have some question about hose routing.
1. What angle tube did you use coming off the throttle body to have the intake end up under the headlight cover?
2. What did you do (and where did you get parts) for the radiator hoses? I figure I can make do with angled bits from what I have, but was hoping to use a long straight aluminum tube for the upper rad hose. Can't seem to find one online.
Old 09-29-2011, 08:34 AM
spazegun2213
spazegun2213's Avatar
damn wally! I'd love to see pics of the setup, if you have any!
Old 09-29-2011, 09:59 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I had a local shop make us a custom intake - they are sort of an import shop so they do a lot of turbo work, but really it was a short piece of silicone hose an aluminum 90 degree going to the MAF another piece of strait aluminum another piece of silicone hose and a filter. That being said I was really happy with the work they did.
As far as the cooling sruff you should be able to find anything you need here.
http://www.hrpworld.com/index.cfm?tp...ction=category
Old 09-29-2011, 10:42 AM
JVetthead
JVetthead's Avatar
http://www.intakehoses.com/
http://www.spectreperformance.com/#HOME
I think the intake tubing came from Spectre.. The piece from the filter has a 30* bend if I recall.. Just cked and it is a 45* bend
Welded tabs to rad and slotted tabs on frame with lord mounts. Loosen nuts and rad pops right out..
Old 09-29-2011, 10:46 AM
travisnd
travisnd's Avatar
That looks awesome
Old 09-29-2011, 10:54 AM
wallyman424
Originally Posted by travisnd
That looks awesome
Yeah, that's a really elegant setup. Too bad Mine doesn't look like that.
Old 09-29-2011, 11:17 AM
JVetthead
JVetthead's Avatar
not sure about elegant... functional yep.
added mount pics
Old 09-29-2011, 11:27 AM
spazegun2213
added mount pics
any pictures of the hood and how your vent works to remove air from the rad?
Old 09-29-2011, 11:30 AM
Falcon
Falcon's Avatar
added mount pics
Is that the regular radiator or a custom fit one?
Do you use a fan?
Old 09-29-2011, 11:33 AM
sperkins
sperkins's Avatar
Benefits of this setup would be?
Old 09-29-2011, 11:34 AM
wallyman424
looks sweet.
I'm doing it for the prospect of better cooling, and also a much more open engine bay.
Old 09-29-2011, 11:47 AM
travisnd
travisnd's Avatar
Because when you take your hood off you get to look down an think "**** that looks awesome"
Old 09-29-2011, 11:50 AM
JVetthead
JVetthead's Avatar
Do you use a fan?
regular c5 Ron Davis with mount tabs welded on
I have not run a fan for 2 years. Gets tricky on grid but once you are moving no problem.
When the weather is cold I preheat the oil tank for less warm up time because cooling water gets hot faster than 3 gallons of oil.
Old 09-29-2011, 11:55 AM
JVetthead
JVetthead's Avatar
looks sweet.
and downforce
Old 09-29-2011, 12:10 PM
JVetthead
JVetthead's Avatar
the rad is not ducted yet other than by the undertray. no problems in Texas heat. I am working on louvers for hood now.Made the fwd lip on hood opening way to big.
Old 09-29-2011, 02:33 PM
Falcon
Falcon's Avatar
Wally, will it be ready for VIR next week?
I haven't made up my mind yet whether to enter or not. I guess I'll wait unti the last possible moment.
Old 09-29-2011, 02:42 PM
travisnd
travisnd's Avatar
Question.... why not just do this? Or similar where the filter/MAF is just on the end of the TB. I'd think that at speed the air flow would negate higher intake temps?
Entrants list is up... Wally's signed up as are 4 other ST2 folks. Last I talked to Ryan he's going too, but not signed up yet. My father will be running HPDE 3... got the last open spot
To question for those of you with laid down radiators
Old 09-29-2011, 02:54 PM
Falcon
Falcon's Avatar
Scott, I think the biggest benefit is easy cleaning of the radiator. Even if fans are installed, it would be a easy to flush out the radiator with a water hose.
Old 09-29-2011, 02:56 PM
travisnd
travisnd's Avatar
Super easy to get at everything in the front of the engine too. Plus if you have a vented hood it shold cool better.
Old 09-29-2011, 03:14 PM
redtopz
redtopz's Avatar
It seems like a more effective way to force the air from a front-feeding setup through the radiator and out through a louvered hood both improving cooling and downforce. Here are some pics of my setup when I bought the car. I'm running a stock LS6 now. Air filter gets cool air from the ds front screen and the oil cooler gets cool air from the ps front screen.
Quick Reply: question for those of you with laid down radiators
