Questions of Installing Race Seat & Wheel in C5
Old 10-11-2011, 02:47 PM
darguy
darguy's Avatar
Default Questions of Installing Race Seat & Wheel in C5
I've got an OMP Grip seat I'll be installing in my '99 FRC, and I'd like to get a quick-release steering wheel at/around the same time. The car is in the process of being transformed from DD/Solo1 into a dedicated road-race car.
I'll be mounting the seat without any adjustments, as I'll be the only one driving the car. I'm 6'1" and wondering what style of wheel and/or extentions folks would recommend?
Can I mount a flat wheel with a quick-release and no extension, or will I necessarily need an extendor (or a dished wheel)? What diameter wheel maintains gauge cluster visibiltiy (I see a lot of 330 mm wheels on-line)? Any specific make/model recommendations (I've been looking at this one)?
Old 10-11-2011, 08:56 PM
TRACKMAN2
TRACKMAN2's Avatar
havent done it on the c5z yet but i use this on the c4 is big good grip good leverage and quick steering and only a few bucks...http://www.speedwaymotors.com/15-inc...wheel,891.html
Old 10-11-2011, 09:28 PM
gmccreary
gmccreary's Avatar
I just put a 350mm Momo steering wheel with a quick release in my C5Z. Here are the parts used:
Quick Release Hub:
http://www.summitracing.com/parts/GRT-3021/
2 inch spacer:
http://www.summitracing.com/parts/GRT-4000/
Grant to Momo adapter:
http://www.summitracing.com/parts/GRT-4009/
Steering wheel:
http://www.amazon.com/Momo-R1909_35S...7704561&sr=1-1
Old 10-11-2011, 09:49 PM
TRACKMAN2
TRACKMAN2's Avatar
Quick Release Hub:
2 inch spacer:
Steering wheel:
spacer huh i dont like how far away the wheel is in that car. i put a custom shaft in the c4 the wheels right up on me its great to drive that way (feel like a nascar guy) ah imean alms guy
Old 10-11-2011, 11:49 PM
sperkins
sperkins's Avatar
Quick Release Hub:
2 inch spacer:
Steering wheel:
Glad you posted that so I didn't have to dig it up again.
The parts above (with 2" spacer) puts the wheel about 1/2" closer than the stock position. It's perfect for me.
Old 10-12-2011, 12:05 AM
mphox
mphox's Avatar
This is what I used...
No extension needed on steering wheel
Hub adapter
http://ltbautosports.com/chco69.html
Quick release
http://ltbautosports.com/ltbquicrelsp.html
Steering wheel 350mm can see gauges fine
http://ltbautosports.com/momomod88.html
a little closer to the driver by maybe an inch, not circle track close, but I like the steering wheel position better than the stock position
Old 10-12-2011, 12:21 AM
96solo
96solo's Avatar
Great info guys. How good is the quick release? Bwwn checking some out.
Old 10-12-2011, 12:33 AM
mphox
mphox's Avatar
The LTB quick release I am using has been great, zero play in wheel, and releases easily.
Old 10-12-2011, 01:45 AM
gtb75
gtb75's Avatar
I just got a 350mm Momo Mod 78 wheel and their QR2 weld on quick release adapter from LTB for my C4 track car... As others have said, no play in the quick release. Nothing else needed besides the wheel and the QR2.
Great people to do business with
Old 10-12-2011, 10:36 PM
darguy
darguy's Avatar
Thanks for all the input, guys!
I'm going to get the seat mounted and then see how much extension I'll need on the new wheel to get it in the right spot. I'll scope out those links and see what fits the bill.
Old 10-13-2011, 09:51 AM
travisnd
travisnd's Avatar
Quick Release Hub:
2 inch spacer:
Steering wheel:
I used the same Grant parts but a Sparco 353... it's perfect and the Grant parts don't have the Corvette-tax
As for seat mounting... there's nothing better than Gary's setup from Hardbar
Old 10-13-2011, 10:29 AM
darguy
darguy's Avatar
Hey that Hardbar mount looks awesome - I'm meeting a fabricator tonight to discuss extending the roll bar into a full cage, and he's also on our club's Tech crew - I'll show him this and get his take on that passing tech. Should be no problem (I'm assuming it's SCCA legal, and the SCCBC generally uses that as a guideline).
Old 10-13-2011, 10:36 AM
travisnd
travisnd's Avatar
To be clear the kit comes with stud adapters to install over the OEM carpet. I'm tall so I went the extra measure and trimmed the stock floor pan (it's got a balsa wood core) to lower the seat as much as possible; most do not do this. It allowed me to ditch the stud adapters and just use the OEM seat studs. I gained 5/8" of head room.
Old 10-13-2011, 01:55 PM
darguy
darguy's Avatar
Thanks for the info - and a good tip. I'm 6'1" so that may be an issue for me as well.
Old 10-16-2011, 03:39 PM
GettReal
GettReal's Avatar
You should get alot of info from this thread.
http://forums.corvetteforum.com/auto...ng-wheels.html
Old 10-17-2011, 03:20 PM
darguy
darguy's Avatar
Thanks for the tip!
I'll be working on getting the seat in next Monday, and then will have a pretty good idea what I'll need for adapters & such. Looking forward to getting this all together!
Question about the air-bag delete: anyone know what size/power rating resistor I need to use to keep the SRS lamp off?
Old 10-22-2011, 05:53 PM
darguy
darguy's Avatar
OK, so we got down to the business of installing the seat last night...
Following the tip to carve out the top layer of composite & balsa to get the seat as low as possible, here's the first track cut:
1/4" plate cut to fit & drilled for the stock seat-studs. Seat bracket positions marked after a test-fit:
Holes drilled & tapped on the rails, bolts tightened & welded on the top side:
Heads ground off & bolt welded on the bottom:
Rails assembled on the bench to the side-mounts & seat in order to square them up:
Completed rails with studs mounted & installed with eye-bolts for the harness attachments:
As it's still my DD, the carpet goes back over the rails & is cut for the new studs and the harness is attached:
Lap & anti-submarine belts attached to eyes. Need to confirm with the club if this is sufficient for Tech, but it gets me rolling for now:
And the finished product - seat mounted to the new rails & harness in place:
It turned out really well - very clean and solid. Made for an interesting drive home - I hadn't realized how much the seat was absorbing the bumps...
Next I'll scope out the race-wheel options in detail & make my selection. As I ended up at least 1" lower, and perhaps a little further from the dash, I'll likely be going with an extender along with the quick release. That will be cool to get set-up!
To Questions of Installing Race Seat & Wheel in C5
Old 10-24-2011, 02:03 PM
travisnd
travisnd's Avatar
Looks like nice work
Old 10-24-2011, 02:29 PM
Falcon
Falcon's Avatar
Did you remove the factory seat studs and replace them with the eye bolts?
Old 10-24-2011, 03:17 PM
travisnd
travisnd's Avatar
It looks to me like it's some type of "eye bolt nut" where-by the circular part has a threaded hole in the bottom.
Quick Reply: Questions of Installing Race Seat & Wheel in C5
