Baseline Bilstein compression rebound numbers?
Old 10-28-2011, 02:03 PM
DaveL82
DaveL82's Avatar
Default Baseline Bilstein compression rebound numbers?
My car is an 80 C3 vette but I would think I could use some input from the C5/C6 guys regarding starting points for Bilstein comprission and rebound numbers (linear or digressive).
Car is used for track days and uses coilover double a-arm suspension in the rear. Front has a fiberglass leaf with older Carrera shocks. I'm looking for baseline numbers for front shocks so I can order some prevalved shocks for coilover conversion in the front. Car uses modern wheels and tires.
Quick Reply: Baseline Bilstein compression rebound numbers?
