Selective ride Yes or No?
Old 01-28-2012, 01:03 PM
speedwaywhite
speedwaywhite's Avatar
Default Selective ride Yes or No?
Trading 08 Z51 coupe next week for Grand Sport, have two to choose from, one with and one without.
I had this option on a 01 vert, wasn't into autox or HPDE then so I didn't use it.
Thanks in advance for the good info!
Old 01-28-2012, 01:43 PM
AU N EGL
AU N EGL's Avatar
Without. never feel the difference
Old 01-28-2012, 08:31 PM
Joezone914
Joezone914's Avatar
If you are gonna do a lot of DE stuff you might consider without. Save money and eventually do an upgrade. Better shocks or a full coilver. If mostly on streets with crappy roads MSRC.
I had pfadt coil over on my z06 and MSCR on the ZR. The coil over is much more precise and confidence inspiring in turns with unstable surfaces.
Joe
Old 01-30-2012, 01:52 PM
Pfadt Racing
Pfadt Racing's Avatar
If you ever gave serious thought to upgrading your suspension it's easier to modify a Non Mag Ride vehicle. Also keep in mind that the Mag Ride shocks are extremely expensive to replace, to the tune of about 500 bucks USD per shock though GM Parts House...
If you want to stay bone stock forever, the Mag ride system may be worth taking a look at. If you ever want to make changes, it's easier without the mag ride.
To Selective ride Yes or No?
Quick Reply: Selective ride Yes or No?
