C7 Z06 frame ??
I thought that I read somewhere that a person going through the plant on the buyer's tour was told that there was an area being renovated with the purpose of bringing the aluminum frame manufacture in-house?
We'll just have to wait and see . . .
What ever happened to all that area that was used for the Caddy XLR assembly line? Seems that if it's not in use, there could be space for frame fabrication. Robotics would the way to do the bending and forming then on to a TIG welding line. Building frams in-house can certainly solve any delivery issues and transportation costs.
I would think that carbon fiber would certainly add strength while taking weight off, but is there current technology to build a car frame from carbon fiber? And how would body shops be able to do frame repairs to cf??
And what would that do to the cost given the 518 Z06's made in 2010 and 904 made in 2011? I could almost see a $100K C7 Z06
Also, is it possible that the front cradle could be going away from magnesium to aluminum? That may be a cost-saving deal and it may be easier to fab the cradle from aluminum. Parts of the body are aluminum and carbon fiber is used in part of the Z06 frame already.
Cruise-In VII Veteran
Mg symbol on each one, I believe it was used as more of a NVH absorbing metal vs. aluminum
good point on the XLR, what's going on over there?
CF? I hope not
where are the C6Z frames built?
I saw the C6 frames welded at BG years ago, not sure if the hydro form process was there?
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Aluminum frame tech info?
I've been interested in the technical details of the Z06 frame. Anyone have a source they can recommend? (Struck out finding anything of substance on the search function.)
Thanks.
Thanks.
They're part of a SAE publication - Chevrolet Corvette New Vehicle Engineering and Technical History - which came out when the C6 Z06 was introduced, and has both a collection of historical SAE papers and papers specific to the C6 Z06. SAE publication PT-118. You probably can find it through sae.org.
It was pricey when it came out (my copy shows a $129.95 price) although I believe the price did come down. Still very interesting for all of us automotive/materials engineers.
Update - you can get the book for $20 through SAE:
http://books.sae.org/book-pt-118
List of papers in this book:
http://www.sae.org/servlets/PaperEve...PROD_CD=PT-118
At this price, it is a "must read" for Corvette/engineering enthusiasts.
Seems that the key to getting the cost of carbon usage down is not only the material cost, but getting manufacturing/process technologies down so that the cycle times (and tool utilization) become realistic.
Magnesium has been used since 1997, about 250,000 Magnesium column/pedal supports installed in the C5
CF? I hope not
CF? I hope not
The first gen MINI also used a mag cross-car beam.
sorry I didn't post it they said it was going back to steel hydro formed frames for all Corvettes.
this was from MT
Reports suggest the Corvette may use an aluminum spaceframe, with the body composed of a mix of carbon fiber and fiberglass. That would be expensive, but it would cut weight -- possibly below 3000 pounds in some models. Like all automakers, GM is looking to cut weight from its new cars, in part to improve fuel economy, and trimming mass will also no doubt improve the Corvette's dynamic performance.
Read more: http://www.motortrend.com/future/120...#ixzz1ku4bA3Py
I guess they are all guessing along with me
this was from MT
Mg has been used by GM in (primarily) cockpit/instrument panel cross-car beam structures. The ability for the cross-car beam to be cast/machined offered dimensional advantages over a conventional steel welded cross-car beam and at a weight savings. NVH benefits came from stiffness improvements (steering column NVH is an important design criteria). Disadvantage for magnesium in vehicle components is its brittle behavior. That's why, in instrument panel structures, when a mag beam is used, steel crush brackets are often used to absorb crash loads (like knee impacts).
C5 upper xbar is alum./also lower alum. w/s frame
The Mg column support in the C5 is strictly limited to the pedal/column area(not a cross-car beam)
NOTE: I'm pretty sure you are aware of the above info, but I may be confused by the use of 'cross-bar' you used as comparison in other cars being made of Mg
Thanks for the link of the SAE book above, looks like a great read, gotta get that
C5 lower xbar(material steel) is bolted to the alum. w/s frame on ends and tunnel in middle
Most of their competitors used multiple welded steel stampings/tubes to form a similar function.
Think of the cross-car beam as the "spine" of the entire cockpit module. I haven't been involved with cockpit engineering for a few years, so I don't know the current GM (or competitive) vehicles.
SAE papers 2005-01-0465 and 2005-01-0466. Both written by GM body structures engineers and Alcoa. Each paper's about four to five pages and discusses material properties and selection, analysis criteria techniques, manufacturing, and a little bit about dimensional control.
This is what I hear from a collector of rare Corvettes in Palm Beach FL. with an inside into GM. All C7 chassis will be modified cary over aluminum ZR1 chassis. Seems that the tooling for the steel chassis has a 20 000 unit run left. All chassis deimensions will be the same. The C7 will be a rebodied C6 and the complete redesigned C8 is at least 3 years beyond that. Only thing that concerns me is if there will still be United States at that time. Mechanically, they will be the same also, with the usual Corvette improvements.
