custom seats used by pros, creafoam
I did a search and came up blank. Is anyone using this. I saw it on bald spot sports. Custom seat used by a few pro series groups. Would it be possible to use this in a c6z06. Wonder if this is in the c6r. They also sell foam for the doors for side impact
yes, but you would need an oversized seat to begin with. The idea is to make a custom insert for each driver, that slips into the frame with you. Unless you share the car with another driver, I think finding a seat that fits you properly would be cheaper and easier.
[QUOTE=davidfarmer;1579908220]yes, but you would need an oversized seat to begin with. The idea is to make a custom insert for each driver, that slips into the frame with you. Unless you share the car with another driver, I think finding a seat that fits you properly would be cheaper and easier.
I've seen the inserts that your speaking of meaning switching drivers. This set up is for the sole driver like the one that's been used by indy. According to what I've read, NASCAR has been looking at them and may have started using them to replace aluminum. Is there any data on the safety of replacing a stock seat with an aluminum or fiberglass seat and mounting it to seat rails. Is this really a safe way to go even if you use a brace from the back of the seat to a harness bar. I'm no expert but I would think that the seat should be tied into the roll cage. Are the seat rails bolted to the frame or the floor pan in a c6 or c5. As a side note we even have companies on the forum that claim their seats are racing seats that aren't even certified some of which iv seen at hpde. I'm not looking to stir the sht I'm only looking to learn whats the proper and safe way to go.
I've done 10 or so over the years, all for open wheel cars with the exception of a set of driver inserts on a Miata for the 25hours of T-Hill.
I've used the Indi-Seat, Bald Spot and Pennon Composite kits.
As David mentioned, you need an oversized seat to start. I'd think you'd want at least 2 inches of material thickness between your ribs and hips (my opinion, talk to Bald Spots).
Done correctly, these seats are unbelievably comfortable. In an open wheel seat, there is zero body movement (damn near feels like you could race the car without the belts on ).
This is the only seat I'll use in an open wheel.
It does take a while to do and you only get one shot to fit the driver.There's cutting/shaping the excess material, putting on the nomex cover (better done by an upholstery shop) and a few "tricks" .
Worth the effort - yep,IMO.
Note: If you have a big impact, the seat should be replaced (even the multi-impact material ones).
That's also why 2-part foam is a bad idea for seat inserts.
