bleeder help
bleeder help
Just tried my new Motive power bleeder for the first time. Works good. Do you guys actually torque the bleeders down when done? or just hand tighten? I only hand tightened and I have two that are giving me ever so small drops of fluid after stepping on the brake to test out. I feel like I don't want to hand tighten anymore for fear of breaking something.
Possibly debris under the bleeder? I would try to loosen and tighten back down, if that doesn't work, remove completely then put back in. If all else fails replace it; not an area I want a leak in!
I loosened and tightened them back down. wiped clean and tested again. seem ok now. I think I will pick up an appropriate torque wrench and socket at some point. I have no real idea how much torque I applied.
You will develop a feel for how tight to go. Trust your feel.
