Header recommendations?
Old 07-21-2012, 08:24 PM
moespeeds
moespeeds's Avatar
Default Header recommendations?
I was going to delete the cats and add an X pipe but after reading up it doesn't seem worth the effort unless you get headers. '00 LS1 stock besides the K&N air filter. The car is off road/track only. Keeping in mind that I'm in this for the long haul, and going forward I may start modding the engine for a little more HP, (nothing crazy) what headers can you guys recommend? Price is the number one concern.
Old 07-21-2012, 08:57 PM
redtopz
redtopz's Avatar
Most of the West Coast T1 racers are running LG Motorsports longtube headers. I've had my pro series headers for years and I'm happy with the results. They are also very light so you will remove some weight. Their street series headers are a lower cost option also.
Old 07-22-2012, 08:49 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
LG. They have two versions depending on mods/power, but their system is the best. Anyone else that has a similar system simply copied Lou's design!
Old 07-22-2012, 09:28 AM
moespeeds
moespeeds's Avatar
Yeah from what I'm reading the LG streets can run up to 450 HP which is more than enough for me. I'm running straight 2.5" pipes, I already deleted the mufflers. Any problem with just leaving off the hoops that go over the axle and just welding some 3" turndowns at the end of the mid-pipe? Aesthetics mean less than nothing to me. The car is only a tool to go faster.
Old 07-22-2012, 11:36 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
LGM Pro Headers
Old 07-22-2012, 02:06 PM
skyavonee
skyavonee's Avatar
Uhh, they'll support far more than that... I promise you won't run into some imaginary wall in the vicinity of 450 hp.
Old 07-22-2012, 02:18 PM
6SPEEDZ
6SPEEDZ's Avatar
Actually Lou copied Wheel to Wheel's header. They were the first with that design. This is not uncommon in the header business. I used to work at a header shop installing all different brands and custom building them.
To Header recommendations?
Quick Reply: Header recommendations?
