someone make this...and sell it to me
Old 09-14-2012, 12:25 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default someone make this...and sell it to me
Id love to, but just dont have the time
Old 09-14-2012, 12:44 PM
RX-Ben
RX-Ben's Avatar
Who designed it? Does it actually work?
Old 09-14-2012, 03:37 PM
VGLNTE1
VGLNTE1's Avatar
judging from how that looks, im sure it works. No idea who designed it, or I would ask them. Just saw this in a diffuser thread in gen section
Old 09-14-2012, 05:16 PM
Rob Willis
Rob Willis's Avatar
That on a c5 or c6?
Looks like a C6 rear.
Old 09-14-2012, 07:32 PM
C5Natie
C5Natie's Avatar
Ive been looking for a rear diffuser like that. Thatll be sweet.
Old 09-15-2012, 10:44 PM
db2xpert
db2xpert's Avatar
If somebody had anything like that tested in a wind tunnel .....
Old 09-16-2012, 06:29 PM
VGLNTE1
VGLNTE1's Avatar
Just use CFD. and test it on track.
Old 09-16-2012, 07:53 PM
AU N EGL
AU N EGL's Avatar
Originally Posted by KBlanke
Hand made, one of a kind.
His IIRC
Old 09-16-2012, 09:48 PM
db2xpert
db2xpert's Avatar
Exactly how would you test and verify a performance improvement by running it on a track?
Old 09-16-2012, 10:01 PM
VGLNTE1
VGLNTE1's Avatar
Is that sarcasm?
Old 09-17-2012, 02:04 AM
MJM
MJM's Avatar
That's a rather steep diffuser. I would like to see the wind tunnel data that proves it creates downforce and doesn't have flow separation.
Old 09-17-2012, 08:42 AM
AU N EGL
AU N EGL's Avatar
I think the designer is an aerodynamics engineer.
This is NASCAR county, we have four Wind tunnels here in NC.
The little aero I have on my car, splitter and spoiler, once the car's rake was set up properly, the difference on high(er) speed corners was immediately noticeable.
Old 09-17-2012, 04:34 PM
db2xpert
db2xpert's Avatar
Wind tunnel will provide real data. Some wings and splitters have been designed and tested, most probably not. There may be a significant difference between those designed and tested in a tunnel.
Did you get a bigger SOP improvement from putting on the splitter and spoiler, or from adjusting the rake after they were on?
I'm not suggesting you didn't get a big overall improvement, since I run both splitter and wing on both cars, and felt the difference on each when they were added. And saw the lap times drop.
I am suggesting that the overall performance benefit may be anyplace between miniscule and fantastic. You can determine this in a wind tunnel, or with a real pro driver that runs consistent lap times within .1 secs..... bolt it on and see what he does. That also needs to be a fast bolt-on install to avoid atmospheric and track temp differences.
IMO, coast downs are not reliable metrics unless you have a ton of electronics to measure everything.
Old 09-17-2012, 04:43 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
There is a MAJOR flaw in that undertray.
Old 09-17-2012, 05:39 PM
froggy47
froggy47's Avatar
I'm going to take a WAG, that flowing from front to back, the really sharp angle that takes place from the curving part to the flat part (which would position approximately parallel to the ground) shouldn't be there?
You may laugh, but I always like to think of fish and airplanes and would you see an angle like that (in the flow direction) on either?
Seems like a turbulant low pressure area would develop (sort of just where you don't want it).
Old 09-17-2012, 05:50 PM
AU N EGL
AU N EGL's Avatar
maybe that is way it was one of a kind. testing it out.
Old 09-17-2012, 06:37 PM
VGLNTE1
VGLNTE1's Avatar
The rounded section instead of flat?
The p1 car in alms. The Honda is all cfd. Never saw a wind tunnel, and its destroying the compitition. With todays tech, we don't see silly tunnels with smoke wands. ;-)
To someone make this...and sell it to me
Old 09-17-2012, 07:34 PM
Falcon
Falcon's Avatar
Wanna bet?
Come over here and park on Mazeppa Road in Mooresville and watch all the traffic coming and going from the wind tunnels.
Old 09-17-2012, 09:09 PM
VGLNTE1
VGLNTE1's Avatar
A lot of people use carburators still too.
Old 09-18-2012, 12:16 AM
db2xpert
db2xpert's Avatar
Right, that's why GM developed both C5R and C6R pieces in their windtunnel.
Quick Reply: someone make this...and sell it to me
