Race Seat, How tight is too tight?
Old 11-11-2012, 09:56 AM
jlutherva
jlutherva's Avatar
Default Race Seat, How tight is too tight?
I've got a Cobra Evolution race seat and it's a very tight fit - there's no wiggle room what-so-ever, not in the thigh, butt, hip or shoulder areas. I've sat in the seat for 10 minutes or so but that's not like like slamming around a road course. My existing seat is a Sparco Evo 2 Plus and after 30 minutes, my hips are aching. BTW, I do have two bad hips.
Thoughts?
Jim
Old 11-11-2012, 10:20 AM
63Corvette
63Corvette's Avatar
Mine is too tight to carry a wallet. It should be loose enough to sit in for a 30 minute race, but tight enough that you could not sit in it for 4 hours!
Old 11-11-2012, 01:01 PM
JerryTX
JerryTX's Avatar
I'm new to the race seat thing so I'm still learning but what I found is what I thought was tight isn't tight enough. I found I'm still twisting my hips and jamming my quads into the side of the seat to hold my lower torso in and it's a distraction; my body should be relaxed and no effort spent pinning my torso into the seat. I have large shoulders so my upper half is pinned just fine. Don't know that it helps you especially with the bad hips, I'm sure there is more to consider giving your predicament..
Old 11-11-2012, 02:56 PM
Joy of 6
Joy of 6's Avatar
Thoughts?
Jim
That's a perfect fit! Also after hooking up your harness, if you can still breath, then they are not tight enough. The only thing you want to move is your hands and feet.
Old 11-11-2012, 07:29 PM
rfn026
rfn026's Avatar
I'm not even sure it's possible to have a seat that's too tight. Once you reach turn 1 you'll want an even tighter one anyways.
Richard Newton
Facebook
Old 11-11-2012, 08:14 PM
jlutherva
jlutherva's Avatar
OK, thanks guys! I'll proceed with the istallation and adjustment process.
Jim
To Race Seat, How tight is too tight?
Quick Reply: Race Seat, How tight is too tight?
