Tricks needed to keep my car aligned.. Keeps coming un-done.
98 c5. Mostly autocrossing. For years I had actual race car mechaics do my alignments. They would hold for at least two years. But these guys are no longer available. So I"ve been taking the car to a local trustworthy shop and giving the guys specs to hit. They do hit my numbers and the car handles great. After I race and am on the way home it starts pulling one way or the other.
Do you guys ever use lock tight or any other products to keep things tight?
Is this an issue where these guys need to put some serious elbow grease to work?
Can they use air tools to tighten things down?
What can I tell your average Joe to do in order to keep the car alignment from slipping out of spec?
Take a look at your lower a-arm bushings. On the early C5 Z06 it was common for the bushings to be crushed to nothing leaving you chasing the alignment as the ruibber deteriorates.
And if you still have problems go to the PFADT Camber Kit, Installed one a couple weeks ago on a C6, its a little time consuming to get right but not much way it can move afterwards...
The PFADT poly kit with offset bolts make it easy to adjust from aggressive setting to less aggressive just by jacking up the car, removing the nuts on the upper studs and flipping the bolts over.........quick and easy 'street' to 'track' and back again.
Check all bushings and replace as necessary. Once alignment is set to your specs mark everything with paint. Get a yellow enamel and small brush. Paint a line across every adjustment point, bolt and eccentric cam. That way you can examine and quickly know if something has shifted. You can also easily restore settings by just aligning everything back up according to the marks.
I had a similar problem with my car. The shop kept telling me this was normal when racing...it's not. I finally brought the shop the torque specs from the shop manual and that solved the problem. They admitted that they felt they didn't normally use a torque wrench
Location: If you don't weigh in you don't wrestle Road America
Torque is supposed to be 125 ft lbs, if they don't torque then they will come loose. Tell them the torque spec and it will probably solve the problem.
