FS # used SKF Whell Bearings..
Old 12-16-2012, 04:37 PM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
Default FS # used SKF Whell Bearings..
We have three lightly used SKF wheel bearings. Very good condition...
$275 per wheel bearing plus shipping.
610-482-0141
jfaphoenix32@aol.com
Old 12-17-2012, 12:33 AM
Dirk Miller
Dirk Miller's Avatar
Default new vs old?
610-482-0141
Are these complete SKF wheel hubs?
If they are, I am sorry but why would anyone want used ones when a complete new one is $350? Do these come w/ ARP studs?
Old 12-17-2012, 07:57 AM
jfaphoenix32
Supporting Vendor
They were used 2 or three times, then removed. $75 is a significant savings. They have the stock tuds in them
Old 12-18-2012, 01:01 PM
jfaphoenix32
Supporting Vendor
pm sent.
Old 12-18-2012, 10:02 PM
Dirk Miller
Default SCF question for a C6
610-482-0141
I went to our local GM dealership and requested a quote for front and rear hubs for my 2008 C6. Not only is the part number different for the front OEM hubs as compared to the rear, but so is the price. So my question is - SKF hubs can be used both on our front and rears correct? Then what is the difference with the OEMs?
Old 12-18-2012, 10:08 PM
Dirk Miller
Default SKF question for a C6
610-482-0141
I just went to our local GM dealership and requested a quote for front and rear hubs for my 2008 C6. Not only is the part number different for the front OEM hubs as compared to the rear, but so is the price. So my question is - SKF hubs can be used both on our front and rears, correct? Then what is the difference with the OEMs?
Old 12-19-2012, 12:06 AM
froggy47
froggy47's Avatar
Old 12-19-2012, 10:54 AM
racer313g
racer313g's Avatar
The same SKF hubs can be used front and rear. SKF doesn't make a front specific hub. The difference is the rears have splines for the axle.
Old 12-20-2012, 06:35 AM
jfaphoenix32
Supporting Vendor
The SKF's are a stronger, stiffer wheel bearing made for high performance driving... The SKF'a have been lasting 3 to 5 times longer than the stock gm bearings from 2008 and earlier vintage.
Old 12-20-2012, 09:03 AM
racer313g
racer313g's Avatar
pm sent....
Old 12-26-2012, 07:37 AM
jfaphoenix32
Supporting Vendor
got it. Two are sold.
To FS # used SKF Whell Bearings..
Quick Reply: FS # used SKF Whell Bearings..
