Diff/Tranny Coolers...Options
Just looking into this but couldn't find an up to date thread that mentions any options except the below.. Are these my only options, if they are, then I need to pick one of them and most likely will aim toward cost?
This seems to be the negative feedback on whats available and the positive is they all work well. Am I missing out on some other kit? I have heard the DRM/T1 kits and they are pretty darn loud.
T1 kit - Loud and expensive
DRM - Loud
LG - Expensive and always run
Steve
DRM - Loud
Steve
I have DRM trans and diff coolers and have been really happy with them. They do make some noise, but I don't hear them over my exhaust on track (nor are they distracting when the exhaust is in quiet mode). Since you can keep them turned off when you're not tracking the car noise isn't a factor for me.
I did the same type of research last year and settled on the DRM kit. Cost effective, It Works!, Comprehensive kit with almost all parts needed included. Here is a thread I posted about my install process with a lot of pictures.
http://forums.corvetteforum.com/auto...ful-hints.html
If your car is dual purpose, no worry about the noise. You just turn the pump off while driving on the street - on track - who cares ?
You could design and put together your own and save some money but I know how lazy you Northerner's can be, something about how cold it is outside
I did mine for about $600 - $700. It's just (2) coolers, (2) 12v pumps, (2) 12v relays and then some wiring, hose and AN fittings. It's all low pressure so it is easy to make the hoses.
Thats kind of the answer I was looking for. I did more searching and found that you can just get the tilton pumps for about 140. each (same as what everyone seems to be using) and a couple BM coolers for about 80 each, so your $600 in parts is what I was thinking as well. Would I really just be paying more for the convenience of having it sent to me in a kit?
However, Its also true that I can be lazy in these winter months (currently 10 degrees f). But I'll have my shop do it in their heated garage, I'll just supply the kit for half the price.
I have 1 Setrab and 1 Mocal. You can get them or Fluidyne for $70 - $100 if you shop in the right places. I bought the pumps the same place I got my coolers and they were less than $140. All the AN fittings cost almost as much as the pumps and coolers. I also put in a filter on the trans system and I have expansion/overflow tanks with 1/4 turn drains.
Received 8,928 Likes
When I bought my T1 kit back in 99 it came with a Fluidyne cooler, all of the control wiring cut to fit, hoses cut to fit, required hose fittings and the Tilton pump. After a couple of years I had to have the pump rebuilt by Tilton. They said it looked like metal particles tore up the pump and suggested I put a filter in the line between the tranny drain and the pump. I knew there was something wrong when the pump started making strange sucking noises.
One way to reduce noise is to figure out how to decouple the pump from the car frame. The T1 pump mounts low on the frame just behind the rocker panel and if front of the inner wheel well on the passenger side of the car. As soon as it turns on the vibration is transmitted to the frame and through the car. If you can isolate the pump so it bolts to something that absorbs the vibration and doesn't transmit it to the frame the pump would be a lot quieter. Probably true of the DRM setups as well.
The T1 kit comes with a 178? degree thermostat that mounts to the transmission case and the cooler would turn on after about 3 laps at the Glen. Had it turn on one time on a long road trip so it is a good idea to install a separate switch in the car somewhere in easy reach. You can also pull the fuse but it is under the hood and can be forgotten so the switch gives you the best way to keep it off when you don't want it on.
Bill
Bill
Perma-cool two in one cooler with fan and two pumps...........works really well. Thermostat controlled off the diff side........filtered and check valved.
CP I'm unfamiliar with how these cars look gutted, but I ASSume yours is in the trunk? I tracked with a group that does 30 minute sessions and managed to overheat the trans there, but on the 20 minute NASA sessions I don't. That said, I'm sure it gets close. My concern with the DRM kits is the fact that they steal your rear brake cooling. There must be another way that keeps your rear brake cooling and doesn't require chopping a hole in your floor?
As far as diff/tranny coolers, if you have a designated race car and are serious about enduro racing or keeping things as simple as possible, I would go with the LG system with dual pumps which are mechanically driven off the rear diff. Very elegant and effective design with no electrical wires or pumps which can fail or blow fuses.
That fan setup looks like it's blowing air down.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hey guys,
You already mentioned one of the key points on our kit, and that is that it is always on, so you don't forget to turn it on during your session.
Couple other benefits
This is how it is typically mounted in a weekend HPDE car.
Diff pump and cover pump
Filter
Cooler Mounted
Now with our kits you can get them in a single stage pump for diff only, or two stage for diff and trans. You can also get the kit as just the fittings, pump, cover, drive assembly for those that want to run your own lines and coolers. You can also get it as shown in the above kit with lines, filters, coolers, and brackets.
So there options when you want to do the kit, so don't let the full kit price scare you if you are putting something together on your own.
If you have any questions, I'm more than happy to help!
- Less wiring
- Lighter weight
- No noise from the electrical pumps
- Less packaging
Filter
Cooler Mounted
