Where do you hold your water when tracking?
Old 01-25-2013, 11:11 AM
FruiTay
FruiTay's Avatar
Default Where do you hold your water when tracking?
I know I'll need lots of water for my first open track but where will it stay put? Do I need a travel buddy? I HATE when water is rolling around the floor.
Thanks guys!
Old 01-25-2013, 11:23 AM
Lawdogg
Lawdogg's Avatar
Short sessions are the norm in open track. You won't need water for the 20 to 30 minute sessions that you will be on track.
Old 01-25-2013, 11:43 AM
z06801
z06801's Avatar
^ yep cooler in paddock
Old 01-25-2013, 01:56 PM
geerookie
geerookie's Avatar
Or your bladder if you want to take it with you
NO Loose items in the car, glove box or console or any compartment inside the car while on track
Old 01-25-2013, 02:08 PM
YYZ06
YYZ06's Avatar
I was going to say bladder but you beat me to it.
Old 01-25-2013, 02:22 PM
AU N EGL
AU N EGL's Avatar
Geez just pee in the race suit. Just Kidding.
Bring a big plastic tub, tarp, cooler, lawn chair and set up in the paddock.
Put everything loose from the car in the big plastic tub. No loose items in the car, no cell phones. no gps devices, Nothing in the glove box, center counsel in the rear compartments. Take out the floor mats too.
Old 01-25-2013, 05:14 PM
geerookie
geerookie's Avatar
When I get stuck helping with DE tech I feel like a TSA Guard walking up and down the tech line saying exactly that.
Old 01-26-2013, 09:47 AM
c4cruiser
c4cruiser's Avatar
The amount of water you will drink can depend on the air temperature. I attend an event at Portland at the end of July when air temps can hit 100 degrees. At those temps I'll usually drink 8-10 bottles of water during the day. When temps are lower (like the usual 50-60 degrees we see in the Puget Sound area) then something like 5-6 bottles will work. I also try to park close to the restrooms....
Events will usually require you to run with windows down, so on a hot day, there are not many ways to cool down.
Some events will provide water for the entrants. But it's always a good idea to bring your own. Get a cooler that will hold enough bottled water and ice. Fill the cooler and add the ice just before you leave home.
Old 01-26-2013, 09:56 AM
Rob31
Rob31's Avatar
A co worker ashed me the same question . I wasnt as nice as these guys .
I told him if you cant go 30 minutes without a water bottle in a car , you might want to try a differant sport .
Old 01-26-2013, 10:13 AM
DansBlkonBlkZ06
DansBlkonBlkZ06's Avatar
A good rule of thumb is if you have to pee before each session, you are drinking enough water.
Old 01-26-2013, 10:38 AM
AU N EGL
AU N EGL's Avatar
Pre session check list:
Tire Pressure
Fuel <------ BIG one. but I bet not one of us, got all strapped in and went to the false grid line up ONLY see the fuel gauge almost on E
Oil level
PEE
Old 01-26-2013, 12:38 PM
Legacy Z06
Legacy Z06's Avatar
You'll hate it even more when that water bottle rolls under the brake pedal at the end of a straightaway. As mentioned no loose items in the car, that includes items you've put in the cupholder. If its not bolted down then get it out of the car. I buy one of those large 1 gallon/4 liter jugs of water from the grocery store for a $1. It doubles as emergency coolant if you loose some fluids at the track. Good enough to get you home.
My between sessions ritual: Pop the hood not only to let it cool down but also check fluids (don't pull rad cap off when hot , people do this), check for leaks, walk around car and check all 4 corners to make sure tires still have rubber and aren't flat/damaged.
Old 01-26-2013, 01:47 PM
fcarga
fcarga's Avatar
"A good rule of thumb is if you have to pee before each session, you are drinking enough water."
And/or nervous!
Old 01-26-2013, 07:36 PM
crease-guard
crease-guard's Avatar
Tire Pressure
Oil level
PEE
I've done this enough times I now make it a point to keep at least a 5 gallon jug handy in case I forget to go to the pump. Got tired of having to pull off the line to haul *** to the pump.
Old 01-27-2013, 08:48 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
or see a doctor.
Old 01-27-2013, 09:28 AM
VatorMan
VatorMan's Avatar
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
I always pop the fuel door at the end of a run to remind me to check the fuel level before the next one.
Old 01-27-2013, 08:00 PM
harrydirty
harrydirty's Avatar
A good rule of thumb.
I also used to not drink before the first session, but once in a while I would get toe cramps, not fun while on track. Finally figured out that I needed to drink before first session, and certainly before I got thirsty. I now drink even though I'm not thirsty to the point I need to pee before a session and problem solved.
Old 01-27-2013, 08:02 PM
FruiTay
FruiTay's Avatar
These are good little pieces of info!
Old 01-27-2013, 08:15 PM
von zoom
von zoom's Avatar
My regular routine, bottle water on ice in the cooler, then drink a bottle of water, pee, drive, drink a bottle of water, pee, drive - - You get the idea.
vz
To Where do you hold your water when tracking?
Quick Reply: Where do you hold your water when tracking?
