Radiator / oil cooler for HPDE
1. Ron Davis or LG? Any major differences?
2. I have a 2003 C5Z and I think (but am not sure) that the oil filter is on the left side. Most radiator Illustrations on vendor's websites have the oil ports on the right side. Are both left and right sided versions available?
Many thanks.
Many thanks.
Received 8,928 Likes
The RD has the oil cooler on the right side. In cool weather the oil will stay very cold since the cooler is on the cool side of the radiator. I had to install a thermostatic control valve in my oil lines so I could drive the car in the winter. On the track the setup works great. My setup was the older DRM version so the oil cooler attached to the oil filter mount on the engine and I had a large remote oil filter installed just behind the radiator. Total oil in the system with the extra quart added when on track was 9 quarts.
Bill
Bill
How savvy are you Mike? I elected to copy Pfadt's setup on my car so as to not preheat the air headed to the radiator. The other bigger benefit, as my car is dual duty, is I can easily plug it and my oil still gets up to temp in the winter. On the street the cooler isn't exposed to the elements, so it'll stay cleaner longer. I dropped from 280s to 250s with an opening that I think I need to enlarge.
Does the RD combo have the oil cooler on the right? I believe the oil filter is on the left. Any problems with the lines crossing?
Do you think that the transmission (+/-differential) cooling is as important as engine oil cooling, with the above temperatures?
I get similar temperatures, high 280s to low 290s, in both the engine and the transmission oil .
I just picked up my '03 z06 from Phoenix. They installed a RD with the integrated oil cooler. Afterward I went on a 40 minute drive to see my parents. It is 22 degrees outside. Took about 15 minutes for the oil to get to 180 and stayed there. I think for me that's fine given how much I drive it in this weather. I can't wait to see the effect on the track. I would do 4 laps at Thunderbolt and be in the 290's. Drivetrain is stock.
Depending on how hard you drive on the track, you may find that the oil integrated radiators do not meet your cooling needs. I had one and it served me well until I improved to the point where slicks were appropriate as were the requisite suspension modifications. At that point the cooling capacity of the oil integrated radiator no longer was meeting my needs with oil temps again approaching 295.
I then went to a Ron Davis water only and Setrab dedicated cooler, both from DRM. On the hottest days at Watkins Glen oil temps eventually get to 245 and water stays comfortably under 200.
If I drive on the street I have to wrap the oil cooler in Saran Wrap to get oil temps above 160. Mine is mostly a track car now, but if I drove on the street more I probably would put in a manual oil cooler bypass valve.
Former Vendor
Model 898 $225
http://www.dewitts.com/collections/a...lines-w-bypass
1139097E $620
http://www.dewitts.com/collections/c...ator-automatic
