Open trailer + wing?
Old 02-12-2013, 02:15 PM
yakisoba
yakisoba's Avatar
Default Open trailer + wing?
I see folks doing this. Is it something to worry about? It would put downforce on the trailer, but if that was in a decent spot, it should not be bad (not lifting up the hitch). Does anyone do this?
Old 02-12-2013, 03:01 PM
AU N EGL
AU N EGL's Avatar
take the wing off is an option.
Old 02-12-2013, 03:33 PM
eogel
eogel's Avatar
I do it. Trailer corners sooo much better!
Seriously, I cannot tell the difference.
Old 02-12-2013, 04:12 PM
yakisoba
yakisoba's Avatar
it is, but it sucks. Hard to carry, easy to damage. I figured, at small AoA, the downforce on the trailer would be minimal especially at highway speeds. I mean the wing is good to over 150 MPH... 70 on the highway ought to be pretty easy.
Old 02-12-2013, 05:08 PM
a12secondscooby
a12secondscooby's Avatar
The downforce generated by any bolt on wing at highway speed is going to be significantly less than the total weight of the car on the trailer (<10%). It should be fine.
Old 02-12-2013, 07:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I agree with above, with all of the turbulence coming off of your truck etc, even in a perfect setup you aren't getting much downforce at highway speed. Downforce is a square of speed, so even a great wing drops pretty low at 55mph
Old 02-12-2013, 09:16 PM
Z06Tracker
Z06Tracker's Avatar
I do this all the time. No issues here.
Old 02-14-2013, 01:58 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
just add a wing on the truck to keep the hitch down!
To Open trailer + wing?
Quick Reply: Open trailer + wing?
