New transmission for Z06 Track Car... has anyone done this?
So I'm thinking that my transmission on my track oriented Z06 is pretty much dead... which already has me thinking about how I want to upgrade on the rebuild. I'm tired of having a useless 6th gear, and I'm not a big fan of the large gap from 4th to 5th. So I'm thinking of going to the ZR1 transmission (with the improved carbon synchros), and coupling it to 3.73 diff gear. If the numbers I'm looking at are correct, this will give me redline top speeds in 1st through 6th (on Hoosier 345/35 tires) as follows:
1st: 65 MPH
2nd: 93 MPH
3rd: 124 MPH
4th: 150 MPH
5th: 185 MPH
6th: 223 MPH
Seems more in line with what I'd want in a 2800 lb track car with approx. 600 RWHP. Taller low gears, shorter high gears, everything closer together to keep the engine in the power band (always above 5.5k RPM). Thoughts? I'm thinking 2nd through 5th would now be ideal on most road courses, and I'd always have 6th for a high speed 1+ mile run (if I ever decide to give that a try).
1st: 65 MPH
2nd: 93 MPH
3rd: 124 MPH
4th: 150 MPH
5th: 185 MPH
6th: 223 MPH
I just switched 5th and 6th gear - now .82 & .70. Kept Z06 3:42 rear. Much better. now a very useable 5th gear for the tracks that you see those kinds of speed. Setup also ran 193.xx at TX Mile with roughly 560rwhp in a full weight street car.
BTW, I'm not sure if my tranny really is dead, but based on the noises and symptoms I was getting after coming off the track, I don't think it's going to be good. The transmission sounded like it had straight cut gears in it, sort of a whirring/whining noise that increased with engine RPM, even when the car was in neutral. So long as the clutch was out, in any gear or neutral, I was getting a whine noise. I even let the clutch out in neutral once and the drag on the engine from the trans stalled the engine. Also I got a "high transmission temp" warning on the DIC which I've never seen before, and the shifting was EXTREMELY notchy/grinding as if the sychros were barely working. Something ain't right!
May want to look at Rockland Standard Gear http://www.rsgear.com/
http://www.rsgear.com/products/trans...tranzilla.aspx
http://www.rsgear.com/products/trans...rmance/c5.aspx
1st: 65 MPH
2nd: 93 MPH
3rd: 124 MPH
4th: 150 MPH
5th: 185 MPH
6th: 223 MPH
1st: 65 MPH
2nd: 93 MPH
3rd: 124 MPH
4th: 150 MPH
5th: 185 MPH
6th: 223 MPH
You might want to take a look at either a 3.90 or 4.10 final drive ratio. Here are the speed in each gear with your Hoosier 345/35R18 tire and a 7,000 rpm shift point:
-------- 3.90 - 4.10
1st ----- 65 ----- 62
2nd----- 89 ----- 85
3rd---- 118 ---- 113
4th---- 143 ---- 136
5th---- 177 ---- 168
6th---- 214 ---- 203
You would be wise to talk to Jeremy at RPM Transmissions - www.rpmtransmissions.com in Anderson, Indiana. They can upgrade a standard ZR1 box, and build you a C6 Base Car rear axle assembly that would be reliable for your road race application. As others have questioned, the only available gear ratio for either the C6 Z06 or ZR1 Corvette differential is the GETRAG 3.42:1 gear set.
Good luck with your decision.
The tranny in my 08Z went last year and I put in an RPM built ZR1 tranny and a Quaife diff. I couldn't be happier other than the fact that the taller first gear is even harder to get going with the stage 3 cam.
I find this somewhat surprising, I have done many many events at many tracks and can't remember the last time I got past 4th gear and that was doing 155+ down pretty long straits
Part of me wanted to go nuts and get this, but after sleeping on it I decided maybe it was just too much:
http://www.lgmotorsports.com/product...oducts_id=2179
Fastest speed I've hit at a track was 161, and that was near redline in 4th in the stock Z06 trans.
That sounds about right, I think I hit 160 in 4th once at Pocono on the long back strait, and that is probably one of the biggest tracks outside of Daytona where you can go that fast.
I (and several others) break the 160 MPH barrier on the front straight at the California Speedway, aka ACS, "roval" configuration. Sounds like you've been in a similar situation... what was it you found surprising?
I know up and down the east coast I can't find a track where I have top speed higher than 160mph (maybe Daytona), but that is also referring to a relative stock car, so I can't comment on your particular situation.
Transmission
I have the ZR1 with 4.1
If you still have a really good motor, which then makes good runs into the high speeds a lot of fun.
Here I have two video of me of "Circuit de Dijon *
Cölestin
Cölestin
