What brake ducts work with Stoptechs ?
Old 05-18-2013, 09:01 PM
Charley Hoyt
Charley Hoyt's Avatar
Default What brake ducts work with Stoptechs ?
I am putting on a set of Stoptech ST 60/40s and just discovered that they interfere with my quantum brake ducts. What brake ducts will work with the Stoptechs?
Thanks,
Charley
Old 05-19-2013, 08:30 AM
MySR71
MySR71's Avatar
Do you mean spindle ducts? If so, I would recommend talking to someone at LG Motorsports. I have some of their spindle ducts with my StopTechs. Mine are from 2004 and I'm not sure how much they have changed their design (if at all). Since they are also a StopTech dealer, I bet you could talk to them about your specific set up (be sure to mention the size brake duct hose you want to use).
Their spindle ducts get sandwiched between the bearing assembly and the spindle so you will have to take the bearing off to put them on. The brake caliper and rotor still lined up great for me on my C5Z06.
Old 05-20-2013, 07:59 AM
taken19
Track Junky
taken19's Avatar
Where exactly was the interference? I ran ST-60/40 in my old C6 Z51 with Quantum brake ducts and didn't have an issue (at least that I knew about).
Please provide details.
Old 05-20-2013, 08:21 AM
JMB92
JMB92's Avatar
I had the same problem. Nothing a little grinding didn't fix.
Old 05-20-2013, 11:03 PM
Charley Hoyt
That looks like the answer. It looks like I need to trim about 1/4" from the air inlet and I will have to cut off the heat shields.
Thanks for the help,
Charley
Old 05-20-2013, 11:10 PM
Charley Hoyt
Here is a picture. In this picture the disk wasn't fully installed because it is interfering with the spindle duct. It is hitting the air inlet at the top and the heat shields on the bottom. Looks like I have some trimming to do....
Charley
To What brake ducts work with Stoptechs ?
Quick Reply: What brake ducts work with Stoptechs ?
