How do you fix a leaking bead on a Hoosier R6
Old 05-22-2013, 07:34 PM
NVR2L8
NVR2L8's Avatar
Default How do you fix a leaking bead on a Hoosier R6
I have been running Hoosier R6s for several years, and for the first time I have a tire that is leaking between the bead and the lip of the wheel.
I am reluctant to use an over the counter sealant because I am afraid that the high temps on track would cause the sealant to de-compose.
Anybody had this problem, or have a good fix?
TIA
Old 05-22-2013, 07:55 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Had the same problem last season. Dismounted tire, cleaned bead of tire and wheel mounting surface. You need to check the tire bead carefully for any damage. Remounted tire and problem was gone. Probably just some junk (small) between the tire and wheel.
Old 05-22-2013, 10:53 PM
fatbillybob
fatbillybob's Avatar
Been through too many hoohoos to count and I mount my own wheels. Hoos have the worse bead flash of any maker that's why you got a leaker. So you deflate the tire and pry the bead down a bit like 3/8" with a tire iron or wide flat blade screwdriver paint in rubber cement or real tire bead sealer. Inflate and you are done. Sometimes if the area is small you can deflate just step on the bead all your weight spray in cheap hairspray and reinflate. Dismount remount is a last resort and sometimes just moves the leaking to another place. You got to peel the flash off or use proper beadsealer.
Old 05-22-2013, 11:53 PM
JRL
JRL's Avatar
Mount with hair spray (Aqua Net). Worked for me. Don't wet beads. Just use hair spray. YMMV
John
To How do you fix a leaking bead on a Hoosier R6
Quick Reply: How do you fix a leaking bead on a Hoosier R6
