Good source for ballast ?
Old 05-30-2013, 09:06 AM
clubracer6
Support Corvetteforum!
clubracer6's Avatar
Default Good source for ballast ?
Need more ballast than anticipated and the lead compact stuff is not that cheap. Anyone know of a good source? We have checked with Summit and a couple of other places.
Thanks!
Old 05-30-2013, 09:30 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I see a lot of SCCA guys using weights from a gym set.
I've always used bar stock - like the piece we put where the rear leaf spring used to be. It can be bolted to the inside of the rear bumper. You can get bar stock in a variety of sizes, I usually use 1"x3" it's a little under 1lb per inch.
Old 05-30-2013, 09:36 AM
clubracer6
clubracer6's Avatar
Cool, thanks Joel!
Old 05-30-2013, 12:22 PM
geerookie
geerookie's Avatar
I usually search ebay for guys unloading ballast.
I have also found guys selling old lead weights then just melt them in a pan and make your own. Just takes an old metal pan and a propane torch unless your wife will let you use the stove
Old 05-30-2013, 12:44 PM
drivinhard
drivinhard's Avatar
ebay is a good place to buy lead, if it fits in a flat rate box, it ships. $15 moves a LOT of lead
Old 05-30-2013, 03:43 PM
davidfarmer
davidfarmer's Avatar
local metal recycling center.....
Old 05-30-2013, 04:13 PM
eogel
eogel's Avatar
...more input on the gym equipment source. I got all the weight I wanted from the maintenance person for a gym chain. Flat and predrilled with holes in several weights. Just happened to see him going to his truck in the parking lot.
Old 05-30-2013, 04:22 PM
clubracer6
clubracer6's Avatar
thanks for the ideas guys!
Old 05-30-2013, 08:25 PM
TLGunman
TLGunman's Avatar
http://www.stockcarsteel.com/tungsten/
Old 05-31-2013, 08:51 AM
moespeeds
moespeeds's Avatar
Originally Posted by TLGunman
No way. What the hell is wrong with lead or steel? Isn't Tungsten mildly radioactive?
Old 05-31-2013, 12:15 PM
GAS
GAS's Avatar
Ummmmm......I have always been a fan of MOO COW beer or anything with sugar in it. The only draw back is you typically have to place the ballast about middle of the car on the left side........
Old 05-31-2013, 05:18 PM
trackboss
trackboss's Avatar
The one drawback to lead is it is extremely difficult to drill for mounting.
To Good source for ballast ?
Quick Reply: Good source for ballast ?
