Improve your ARE Dry Dump System
Has anyone tried to adapt this to the stock dry sump system on the LS3 or LS7? My understanding was that the problem with the stock system was too much entrained air at high lateral G loads (such as those produced when driving on sticky tires). This system would seem to help that problem, yes?
I have raced many cars and have known Gary Armstrong's ARE Dry Sump systems for years. There are no better systems and no better guy to work with. And, a big plus in my opinion, Gary is a devout Christian.
Just an old man's 2 cents!
Jim
By the way, Katech also installed piston squirters in my engine when they built it, another engine and piston life saving device.
Jim
Sorry to be so slow posting guys. I am in a rental house and the guy that owns the property was cutting the grass and cut my cable. All is well now.
Jim
Here is a picture of the install, Ron. We ran it with the air bleed to the dry sump tank not attached and then attached it. I believed Gary but I was quite surprised when the Dry Sump tank level wend down so fast. Remember, my system is an ARE stage III system.
THIS THING WORKS GUYS!
I might add I am surprised by how many times I see race cars where the area around the radiators and coolers are not completely blocked off so all the trapped air does not go through the coolers. This product will reduce oil/water temps but so will forcing all air through the coolers.
MANY THANKS GARY!
Jim
Hi all, and thanks to Jim for his posts, and great photos. The Spintric has been used primarily on stage 3 systems, on LS as well as other systems with our 4 stage pumps ( 3 scavenge) ,however, all dry sumps are "over scavenging" the pan, as it is the nature of the system. The Spintric helps separate the 2 again, so the tank can be more oil tank than air/ oil tank! This is the reason the level sometimes goes down slightly, as less air is in there to displace the oil. There were questions about the a/c, and it is true on our Stage 3 LS 1-6 systems, normally the pump is "direct to block "mounted,where the A/C was, however, on the ZO6 LS7 retro fit dry sump system like Jim's, the A/C stays put! We also make a track day system for the LS 1-6 C5. C6 Corvettes, Camaro, etc ( anything LS powered) that uses a 2 scavenge cyl head mounted pump in a system we manufacture for the specific reason of keeping the Air Conditioner and factory damper in place. Great for dual purpose cars, but I always recomend our DTB systems for serious race cars. More info is avaiable at www.drysump.com and www.spintric.com. Thank You! Happy 4th and God Bless te USA! Gary Armstrong
Any thought to making a retrofit kit with lines and mount for folks with the stage 3 system like Jim and I have? Doesn't seem too difficult to install if you have the right parts and know what line goes where.
Thanks for the info. I sent you a PM as I did not want to derail this topic.
Jim
So if all dry sump systems are over scavenging the pan, spintric should help on even the stock system, correct?
Jim
Line size makes a big difference. Early Z06s did not have enough scavage volume. I would be worried about installing it on a stock scavage pump. Mine is installed on a secondary scavage pump that sends a lot of oil and air back to the ARE tank. However, Gary may say it is "OK" to install.
Jim
Jim
The Spintric will work, and will help on any dry sump systems scavenge return to the tank. However, the factory lines would need to be adapted to an Aeroquip type fitting to "splice" it in line. Also, the factory tank would need to be modified for the air return from the Spintric. There are many advantages with the A R E retro fit ZO6 system over the stock system when high lateral G's are involved ( ie any track car) and the oil control in the A R E dry sump pan and tank is the #1 benefit. The Spintric helps the deaeration of the oil one step further. If you wanted to start with that, it sure wouldnt hurt. I would contact Katech or any number of the pro builders selling our systems and see if they have a factory line to AN fitting adapter. Best wishes, Gary
#33
Spintric
Thanks to all our great customers, and I might add that it makes it easy to be helpful and polite when 97% of all our customers are the same way. I do appreciate the excitement and professionalism that most of our customers have. When my feet hit the ground every day, even after 39 years building racing engines and components, i am ready to design more!
Sincerely, Gary Armstrong
#35
Late seeing this post, but I was there at VIR with Jim and witnessed all he said. It is an amazing system, simple in design but highly effective. Will be putting one on my race car soon. Jerry
#36
Here's a recent Tech Article. Link can also be found at www.drysump.com.
http://www.corvetteonline.com/oiling...lears-the-air/
