Alternate Location for Oil Cooler?
I have a C6, LS3, blown. All the air going through the grill is ducted through the intercooler. So that heats the air up before it ever gets to the radiator. I also have a AC condenser that completely covers the radiator, as this is also my DD, here in Texas. Of course that is off during track days. My radiator is just water, nothing else plumbed to it. I have no oil cooler, or any other fluid coolers.
Whatever shrouding the car came with, it was removed to add all the ductwork for the blower. The radiator has air gaps all the way around it. I have tried to seal that up some by adding some sheet metal to the biggest gaps, but still not sealed.
On my first track day with the blower, the water was fine, but the oil got really hot, 290+. So, I'm thinking I'll add an oil cooler. The problem with the traditional location, in front of the radiator, is now I have ONE MORE HOT THING in that same air flow. I'm concerned that this will just make all of it run too hot. I'd really like to get an alternate air source for the oil cooler.
So two questions: One, does anyone track a blown Vette regularly, and if so, where do they put their OC and does it work? And two, if I wanted to put it elsewhere, any good suggestions?
Yeah, I may be overthinking this, I just hate to burn money on upgrades that I then have to take back out and try again.
Thanks.
Thanks.
I've instructed in blown cars in Texas in the summer. Heat management is part of the event for such. To answer your question, there are few places better than the radiator. You can go in under the headlight and replace one of the brake ducts with an oil cooler duct; might even want to put a fan behind it for those times when you have a hot car but you need to stop (for a red flag on track or other reason). Brake ducts are behind the engine for cooling priority, IMO. Just remember that cooler is up there if you hit anything. You can also look into liquid/liquid heat exchangers. Ron Davis Radiators sells them and they may be just what you're looking for. Smaller, and do not require airflow so can go lots of places.
Ha! Believe me, I've looked at the C6R, with its big fan at the back of car, I wouldn't mind having one of those. But yes, it's a street car. Indeed, my daily. Compromise, compromise, compromise.
Aren't the factory brake ducts on the bottom of the bumper facing the ground, NACA style? Does your C6 have a sizeable lip on the bottom? If it's like the C5, I've been thinking, if I'm willing to chop up the bumper, that a horizontally mounted heat exchanger (for whatever you want to cool) would be effective if mounted in front of that lip as that's a high pressure zone.
1st do you have a DeWitts radiator the stock one isnt up to the task for Texas on the track. May want to look into ducting behind the foglight.
For track use you need all the brake cooling you can get.
Lots of work but great temp control with good airflow.
Did this for an automatic but can do the same for oil.
anywhere that there is air flow, or the ability to put a fan, will work. . Nice setup above with simple tin and plastic, but you just don't want to steal air from the radiator as you know. Long oil runs to get to the back, but lots of options back there with shrouded fans.
