Which 5/6 point harness for Corbeau A4's with no sub belt hole?
Old 07-13-2013, 08:09 PM
BoostedEBZ06
BoostedEBZ06's Avatar
Default Which 5/6 point harness for Corbeau A4's with no sub belt hole?
Hey fellas,
I recently installed a set of Corbeau A4's in my C5Z and they don't have a sub belt hole I wanted a set with but I got a really good deal on them so I couldn't pass them up.
Is there any 5 or 6 point harness I can use with these? or will I have to sell them and get FX1's?
Old 07-13-2013, 09:32 PM
mindvexed
mindvexed's Avatar
I was in the same position, so a couple months ago I called up Corbeau and they sold me sub belt grommets so I could add them myself. I think they were less than $20/ea.
Old 07-13-2013, 11:01 PM
BoostedEBZ06
Nice, yeah I was wondering about that. Did you have to cut the foam from your seat? How was the installtion of those?
Old 07-13-2013, 11:23 PM
mindvexed
mindvexed's Avatar
To be honest, they're still sitting in the box. I've been meaning to build brackets for the belts to mount to first and install the grommets once I had the pass-through location figured out.
On my A4s, the cushions are individually wrapped and sit on top of the seat. So you'd have to cut through the fabric/cushion as well as the bottom of the seat. The grommets are a two piece design where the bottom half slips into the top. So I'm guessing you just glue them together, but as I said, I haven't got that far yet.
Old 07-13-2013, 11:27 PM
BoostedEBZ06
Oh okay, yeah I mean it's obvious I would have to cut them not a big deal.
You may be able to answer this too, I would need a sub belt bar mount as well such as this one?
http://www.tpsmotorsports.com/vettew...-belt-bar.html
And the lap belts can mount in my stock belt position correct?
Old 07-14-2013, 07:58 PM
SunnydayDILYSI
SunnydayDILYSI's Avatar
On my stock seats I used these.
http://www.bkauto.com/R_9115_Lap_Bel...5_p/r-9115.htm
And a 6 point harnesses from Wesco. The sub-belt and lap belt both mount onto the kit from BK and you sit on the sub-belt.
Old 07-14-2013, 10:26 PM
steponc
Support Corvetteforum!
steponc's Avatar
St. Jude Donor '14
Default 6 Point Harness
Give MSI a call. Supporting vendor in Roseville. They have a bracket that attaches to the OEM seat belt bolts so you can use both stock belts and a six point harness that doesn't require holes. Talk to them about their harness bar if you don't have one. I'll be at Solano this weekend if you want to look at mine.
Steve
Old 07-17-2013, 12:02 AM
CliffyDeuce
CliffyDeuce's Avatar
In my C6Z, used a similar B-K kit. Allows use of 6-pt harness without cutting; also does not affect stock belt usage (if you need them). Made it really easy.
Old 07-17-2013, 08:35 AM
Scooter70
Scooter70's Avatar
TeamTech Jet Pilot does not require a sub hole.
http://hardbarusa.com/hardbar/produc...3585e724856cd5
To Which 5/6 point harness for Corbeau A4's with no sub belt hole?
Quick Reply: Which 5/6 point harness for Corbeau A4's with no sub belt hole?
