What Size Rain Tires Do You Run?
Old 10-28-2013, 12:27 AM
Olitho
Olitho's Avatar
Default What Size Rain Tires Do You Run?
What size rain tires do you run when racing and why?
What brand and model do you use?
Racing or track days?
Old 10-28-2013, 09:38 PM
Olitho
Olitho's Avatar
No one here races or does track days in the rain?
Old 10-28-2013, 10:38 PM
J.R.
J.R.'s Avatar
Oli,
305 Hoosier wets.
Reason - I had 275's prior and I feel the 305's have more grip. Run about 4 lbs more pressure than normal pressure in Hoosier R6's.
J.R.
Old 10-28-2013, 11:14 PM
Olitho
Olitho's Avatar
Originally Posted by J.R.
Oli,
305 Hoosier wets.
J.R.
Thanks JR. Why did you not go to 315s?
Old 10-28-2013, 11:25 PM
J.R.
J.R.'s Avatar
In talking to couple of engineers they felt the 315's were too wide based upon car weight and weight distribution (49/51). I.e. they thought the 315's would hydroplane easier and not displace the water as quickly as 305's. This is obviously dependent on the amount of water on track.
I have no independent testing to validate this.
Old 10-29-2013, 10:59 AM
Olitho
Olitho's Avatar
That is my thinking, too. I too do not have any data to validate this either.
Oli
Old 10-29-2013, 11:12 AM
63Corvette
63Corvette's Avatar
I was unable to convince Bob Woodman Race Tires to bring Hoosier Wets to CoTA for the SVRA Vintage Championships, so I ran sticker Goodyear Sports Car Specials (dry tires) and they worked pretty good in the wet at that track (I only spun once at turn 19). HOWEVER, in the (wet) GT/GTP Enduro, there were F1 cars, P1 and P2 Prototypes, and Indy cars all running full slicks! Very scary place in the wet. Yes, there were multiple drivers, who had incidents attributed in part to the wet track.
To What Size Rain Tires Do You Run?
Quick Reply: What Size Rain Tires Do You Run?
