How does clutch pedal sw attach to firewall?
Old 11-30-2013, 04:27 PM
froggy47
froggy47's Avatar
Default How does clutch pedal sw attach to firewall?
It looks like a rectangle black plastic and attaches to a metal bracket somehow. Can't tell how. I want to build it up so it's like a clutch pedal stop so my pedal travel doesn't so far.
I think it's part of the stuck down pedal problem that the pedal moves the slave shaft too much.
It's a wonder it hasn't gone to pieces already, I hammer it down pretty good on shifts.
If you can describe how it attaches, before I break something I would appreciate it.
I know a vendor sells one, but it looks over complicated.
Old 12-01-2013, 11:57 AM
JDIllon
JDIllon's Avatar
Get a clutch pedal stop from ECS. It's easy to install and works great. If your clutch engages near the top of your travel? you can reduce your peddle travel. I can shoot some pictures if you need them. JD
Old 12-01-2013, 01:27 PM
froggy47
froggy47's Avatar
If I cut the tab off the pedal to install, then later take the ecs off, will the pedal still depress the switch (without the tab)?
Old 12-01-2013, 04:58 PM
JDIllon
JDIllon's Avatar
Mine would!! just take a flash light and look to see if it still hits the button. Or leave the clutch stop on and reset to old position most people will never see it. JD
Old 12-01-2013, 05:07 PM
froggy47
froggy47's Avatar
Thanks, it looks like once the tab is cut, the rest of the pedal shaft would contact about 1/2 of the switch, I may give it a shot.
Old 12-01-2013, 07:22 PM
JDIllon
JDIllon's Avatar
Give me a call if I can help. JD 772 335 8318
Old 12-01-2013, 08:42 PM
froggy47
froggy47's Avatar
That's very kind, thanks.
Maybe take a week or so to get here.
I'll shoot a vid of the install.
To How does clutch pedal sw attach to firewall?
Quick Reply: How does clutch pedal sw attach to firewall?
