C4 2014 autox suspension setup Looking for advice.
Old 12-29-2013, 11:00 PM
lozer
lozer's Avatar
Default C4 2014 autox suspension setup Looking for advice.
For the 2013 year i came in second overall with 4 wins out of the 5 i ran with this car. (89 vert with super ram 383)
2013 setup was ( this pushed just a little at the limit)
Spring
F 115.5
R 87.5 (The jacking was addressed by keeping spare tire and minimizing rear ride height to be +1/4" higher then the front)
Sway
F 26t
R 22S
Purposed 2014 setup
Springs
F 115.5
R 57.2
Sway
F 32S
R 26S (ride height will be 1/2" greater then front)
Alignment for both years will be
F -2.5 Camber +3/16 Toe out
R -1.5 Camber 1/16 toe in
With this setup i can ditch the extra weight from the spare and assembly. I am also striping the interior and removing the headlight assembly's, a/c setup and audio, ect..
I guess i'm wondering if i'm being a jackass by going from what was clearly a working setup for me and trying to improve.
Old 01-06-2014, 10:33 AM
jamesNewman
jamesNewman's Avatar
Call Sam Strano @stranoparts.com? He can get you sorted out in the right direction. Both of my Corvettes were/are Strano cars.
Quick Reply: C4 2014 autox suspension setup Looking for advice.
