drain fuel tank?
Old 01-06-2014, 03:08 PM
mgarfias
mgarfias's Avatar
Default drain fuel tank?
I need to dump the 1/2 tank or so I have in the car. I had thought I could open the schrader valve on the fuel rail and kick the ignition on and pump the fuel out - but the pump runs for just a sec or two, not continuously until pressurized like I had assumed.
Any easy way to drain without resorting to a siphon?
Old 01-06-2014, 03:29 PM
RX-Ben
RX-Ben's Avatar
http://www.racetronix.biz/itemdesc.asp?ic=FDK-C5&Tp=
Old 01-06-2014, 04:42 PM
mgarfias
mgarfias's Avatar
Nice. Ordered.
Old 01-06-2014, 05:13 PM
travisnd
travisnd's Avatar
Stick a wire in the fuel pump relay holes... costs nothing.
Old 01-06-2014, 05:16 PM
Screamin Z
Screamin Z's Avatar
Make sure the wire isn't too big or you will be buying a new relay box.. Trust me... I know!
To drain fuel tank?
Quick Reply: drain fuel tank?
