Autocross vs. Track Day set up
Old 01-06-2014, 04:26 PM
sfsvettes
BubbaHut
Support Corvetteforum!
sfsvettes's Avatar
Default Autocross vs. Track Day set up
On a C5 Z06 how much diff is there between a car properly set up for HPDE track day car vs. autocross set up etc ?
Im looking for a autocross car , but I seem to find more track purpose cars available right now.
Not sure if a HPDE car will perform as well in an a lower speed autocross enviroment.
I need some help on this ?
My idea, is to find a decent C5Z with good shocks/springs/bars and a set of Hoosiers or V710's ?
Old 01-06-2014, 04:47 PM
brkntrxn
brkntrxn's Avatar
An Autocross car will not need things like oil cooler, tranny cooler, diff cooler, Cool Suit setup, fire extinguisher, full cage, etc.
Old 01-06-2014, 05:08 PM
mountainbiker2
mountainbiker2's Avatar
Just go buy a stock C5 Z06 2002-2004. Put on Hoosiers A6's on the stock wheels. No need for oil coolers, fancy brakes, coil overs, etc. You will be faster then 95% of the cars out there. I just bought a 2004 Z06 and did the following mods. Stock rear wheels 18x10.5 on all 4 corners. 315/30/18 Hoosiers A6's. 35mm front sway bar. Hotchkis rear sway bar. Great Alignment. That's it. It makes me smile every time I Autocross it.
Last race.
Steve A.
Old 01-06-2014, 05:23 PM
acrace
acrace's Avatar
If you're looking for an autocross car, have you thought about what class you want to run the car in? Semi-serious or just for fun? The other posters are correct - there's stuff on a track day car like cage/seat/harness (safety) and coolers (durability) that you don't need for autocrossing, and other stuff (like a gutted interior) that would put you into a much higher class for autocrossing.
As mountainbiker2 said, getting a nice clean stock C5 Z06 and doing bar/basic shocks (Koni 3013s)/alignment will get you a nice car, and one that is capable of being near the top at national level autocross events in the Super Stock class.
Old 01-06-2014, 07:16 PM
rfn026
rfn026's Avatar
The biggest difference will be in the driving style.You need to be really aggressive in AutoX. Driving on the track not so much.
Richard Newton
Old 01-06-2014, 09:50 PM
sfsvettes
BubbaHut
sfsvettes's Avatar
would a track car set up still work well as an autocrosser ?
Too soft or too stiff ?
Old 01-07-2014, 06:38 PM
acrace
acrace's Avatar
http://www.sccaforums.com/forums/aft/444873
Check out the above link and you're all set.
Old 01-08-2014, 09:57 AM
sfsvettes
BubbaHut
sfsvettes's Avatar
Default thanks
thanks for the heads up.. i will check it out...
Old 01-08-2014, 03:55 PM
Bad Karma
Bad Karma's Avatar
Class setup within autocross could make a big difference. Brake pad choice would be different too; Autocross you want good initial bit, on the track something that can really take the heat.
Old 01-08-2014, 05:28 PM
mountainbiker2
I like hardly any initial bite. If you only want to scrub off a few mph, it's hard to do with high initial bite. It's different for everyone.
Steve
Old 01-08-2014, 05:48 PM
63Corvette
63Corvette's Avatar
For Autocross, I personally want great initial turn-in, but very quick rotation.
For track, I personally want great high speed turn stability, coupled with good initial turn-in and good corner exit traction.......however this last one is also a requirement for Autocross.
I never use 1st gear for track, but might use it for slow areas of a tight Autocross.
Old 01-09-2014, 08:22 AM
rfn026
rfn026's Avatar
You want a brake pad that doesn't need a lot of heat. My track pads work best at about 900-degrees. A good street pad will work at around 400 to 500 degrees.
Richard Newton
Car Tech Stuff
Old 01-09-2014, 11:35 AM
Bad Karma
Bad Karma's Avatar
Steve
I should have put good bite when cold, meaning I'd want a pad with a lower temp range for Autocross and for the track if it takes a lap to heat up the pads to their optimal operating range, no problem as long as they ritjdyand yhr heat of a session. But that same pad will not hit its optimal temp range around a short Autocross run.
To Autocross vs. Track Day set up
Quick Reply: Autocross vs. Track Day set up
