Hood Pins
Old 02-14-2014, 03:17 PM
DillingerRadio
DillingerRadio's Avatar
St. Jude Donor '14
Default Hood Pins
I asked recently in the C6 forum about hood pins and it was suggested I ask here instead (they gave me some info. but I imagine they're right, this is a better place to ask!). So I have the following questions about hood pins (I've never had them before, my previous vehicles were classic muscle/show and not driven aggressively on track):
I'm looking at picking up a new hood from LG, the listed options are either hood pin or OEM hinge style. The problem with the OEM hinge style is it adds $900 to the price which is a bit much so I wanted to get the skinny before I take the plunge.
How many hood pins are required (I've heard four, but only ever seen two)? Where and how are they mounted on a Corvette (since the latch mechanism is towards the driver and not the bumper as in traditional hood styles)? I'm assuming I'd have to completely remove the hood whenever I need to get underneath it, since pins eliminate the hinge mechanisms; am I correct in that thought? Finally, how difficult is it to go back to a stock hood if I should ever choose to do that?
My Corvette is a 2010 3LT GS, with 670hp/565lbs-ft torque (full mods listed under my username). The ultimate purpose will be to have a daily driver that I can take to the track on weekends and have fun with without worrying about any potential issues.
These are the pins I'm looking at possibly getting (opinion or suggestions are welcome):
http://www.andysautosport.com/chevro...r00000005.html
To go with this hood:
http://www.lgmotorsports.com/product...oducts_id=1958
Basically- I'm looking for answers to those questions, and any opinions you guys might have. Is it, in the long run, worth going with the hinged hood or am I better off with the pinned one?
Old 02-14-2014, 03:39 PM
RX-Ben
RX-Ben's Avatar
Your links don't work, but you can get them from Five Star.
4 pins.
Need to take the whole thing off, which might be an issue if you care about pain on the edges of the hood.
You will probably need to weld bases (or somehow anchor) for the front hood pin mounts, so you would need to remove those to go back to stock.
Old 02-14-2014, 03:46 PM
DillingerRadio
St. Jude Donor '14
4 pins.
Crap- sorry about the links, they've been fixed, thanks for the heads up!
OK so four, and welded, fair enough! I think that answers most everything. As for hood paint- I wouldn't be worried about it, the intended hood will be carbon fiber (not painted) and carefully removed/replaced so as not to ding or damage it! Thanks for the info!
Old 02-14-2014, 04:02 PM
RX-Ben
RX-Ben's Avatar
You should get the original AeroCatch pins, the knock offs are not good. http://www.aerocatch.com/ (will need to order from a US reseller)
Old 02-15-2014, 12:51 AM
DillingerRadio
St. Jude Donor '14
Ahh, fantastic- I'll definitely get the originals then, didn't realize those were knock offs! Thanks for the heads up!
To Hood Pins
Quick Reply: Hood Pins
