Purchasing first track wheel/tire set - a few questions
Old 03-14-2014, 09:41 PM
klieber
klieber's Avatar
Default Purchasing first track wheel/tire set - a few questions
I've searched quite a bit in the forums and got quite a bit of info from the "what I have learned" sticky. That said, as I look at my first tire/wheel purchase, I still have a few questions/clarifications I'm hoping to get some help with.
I run mainly HPDE events and informal track days. Nothing sanctioned or formally competitive. I'm not good enough to worry about eeking out every last tenth of a second from my tires, so I'm just looking for something that's a step up from high performance street tires. What I would like to purchase:
  • GM Speedline wheels -- 18x10 all around
  • Toyo R888 tires
Ideally, I would like to run the same size tire on all 4 wheels so I can carry a 5th spare around, which leads to my questions:
  • Can I reasonably run the same size tire all around or am I asking for problems?
  • I can't find a clear answer on whether doing this will cause problems with the ABS and/or active handling. Some threads say yes, others say they run with no problems.
Thanks!
EDIT: Subsequent to posting, I found this site which seems to suggest I can't run the same size tire. Does the computer just complain about it or does it actually shut off ABS and/or active handling?
Old 03-14-2014, 10:02 PM
UstaB-GS549
UstaB-GS549's Avatar
You just cannot run a larger front tire unles you trurn off TC. Same diamter front and rear is not a problem with C5.
Old 03-14-2014, 10:23 PM
klieber
klieber's Avatar
OK, thanks for the reply. If I'm going to run the following tires:
  • (2) 275/35/18 Toyo R888 - fronts
  • (2) 305/35/18 Toyo R888 - rears
Can I run them all on 18x10.5 speedline wheels or do I need 9" wheels on the front?
Old 03-15-2014, 01:10 AM
Last C5
Last C5's Avatar
I run 18X10.5s with 315/30/18s on all four corners - no problem.
305/35 will work on all four corners too.
Old 03-15-2014, 12:25 PM
klieber
klieber's Avatar
Do you run with the nannies on or off? If on, does the computer complain at all?
Old 03-16-2014, 10:34 AM
emptnest
emptnest's Avatar
Default Subscribed
I have same questions.
Old 03-16-2014, 05:20 PM
savage
savage's Avatar
Default No nannies
AS SOMEONE else said your ok to run all the same wheel/tire size with no nannies/trouble. your rears are 305/35/18, they are taller than the 275/35/18 fronts. feel better?
Old 03-16-2014, 05:23 PM
savage
savage's Avatar
To Purchasing first track wheel/tire set - a few questions
Quick Reply: Purchasing first track wheel/tire set - a few questions
