I am 6'1" tall, is it possible to install a roll cage in my C5z with the OEM Roof
Hi all,
Like the title states, I am looking into caging my C5z. My cage builder is concerned that there will not be enough room in the car to get the 2" minimum required head clearance from the main hoop with the OEM roof/b-pillar intact.
Thoughts/Experience?
Pictures will be VERY helpful.
Received 8,928 Likes
I had a Kirk Roll Bar installed in my C5Z. Their roll bar was just the rear portion of their cage so the cage cross bar mounted in the same place.
Is he installing the overhead bar in front of the stock halo? I know that Kirk bar/cages have the bar mounted under the halo which may move it back far enough for your head to clear.
http://www.kirkracing.com/C5%20thru%...nside%20EM.jpg
http://www.kirkracing.com/C5%20thru%...%20section.jpg
Bill
Bill
Hi all,
I am also looking into building a rollcage and have compiled the pictures of all the rollcages I could find. You can get the doc here: https://dl.dropboxusercontent.com/u/...0rollcages.pdf
Hi all,
Bill
Bill
Bill
I'm just under 6'1" and my cage (built by Phoenix) is compliant. You might have to experiment with seat angles. If you have a capable cage builder it shouldn't be an issue. 6'1" isn't exactly huge by any standards.
The way it reads I can see it applying to only open cars, but maybe closed cars as well?
Another general question, is there a rule dictating a maximum angle for the main hoop? I ask because I see lots of cages with the main hoop welded to the floor behind the seats (these have some angle), and others that stay straight and go through to the frame by the fuel tanks.
Thanks for the feedback thus far guys.
Good question, now that I am looking through the NASA CCR I don't see a specific 2" rule. I do however see the 2" rule in the SCCA rulebook on page GCR 109-111. http://scca.cdn.racersites.com/prod/...R%20March1.pdf
B.
MAIN HOOP
1.
The main
hoop (behind the driver) must be the full width of the
cockpit for all cars. It must be one continuous length of tubing
with smooth bends and no evidence of crimping or wall failure.
The main hoop must maintain a single plane.
a.
On all closed cars,
the main hoop must be as close as
possible to the roof and “B” pillars.
The 2" rule is for open cars.
