Alignment suggestions??
Old 03-24-2014, 06:16 PM
BlueAngelSAE
Support Corvetteforum!
BlueAngelSAE's Avatar
Default Alignment suggestions??
Will be heading out to Daytona HPDE for new days 4/10 4/11, PBIR 4/12 and Sebring 4/14 and 4/15, I am still running street tires on a 2012 grand sport and will be trailering to the track. I attached the setting of the last alignment any suggestions on if I should take it to get a different alignment for the track? Thanks,
Scott
Old 03-24-2014, 07:23 PM
Solofast
Solofast's Avatar
I would max out the negative camber in front and go for about 1/2 a degree less in the back. If the car is driven on the street a good bit this really won't eat your front tires that bad. Four or 5 track days without enough negative camber will eat at least a set of tires, so what you have probably isn't enough to save them. This would most likely be about -2 degrees in the front and -1.5 in the back.
If you do still drive the car on the street I'd put in zero front toe and a bit of toe in in the back. If it isn't going to be street driven I'd go with some toe out (1/8 inch or a bit more) to improve turn in. NEVER put any toe out in the back.
Caster is good, but if you max out the negative camber you may not get as much caster, but take what you get.
Old 03-25-2014, 08:31 PM
BlueAngelSAE
Originally Posted by Solofast
I would max out the negative camber in front and go for about 1/2 a degree less in the back. If the car is driven on the street a good bit this really won't eat your front tires that bad. Four or 5 track days without enough negative camber will eat at least a set of tires, so what you have probably isn't enough to save them. This would most likely be about -2 degrees in the front and -1.5 in the back. If you do still drive the car on the street I'd put in zero front toe and a bit of toe in in the back. If it isn't going to be street driven I'd go with some toe out (1/8 inch or a bit more) to improve turn in. NEVER put any toe out in the back. Caster is good, but if you max out the negative camber you may not get as much caster, but take what you get.
Thanks for the feedback, I still use on the street and probably just do a before and after alignment.
Old 03-26-2014, 03:58 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
If you are in Raleigh - where do you get your alignment done?
-Ken
Old 03-26-2014, 04:53 PM
BlueAngelSAE
Originally Posted by KNSBrakes
If you are in Raleigh - where do you get your alignment done? -Ken
yes in Raleigh....I am guy that stopped by a few weeks ago with aluminum trailer when picking up Carbotech and rotors.....last one place in Cary downtown ..name is slipping my mind But I recall it's next to pure gold.
Suggestion?
Old 03-26-2014, 05:32 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
Oh hey!!
You are talking about Mark's place - Performance Chassis. For a performance alignment that is the best place.
I was lucky and able to borrow my landlords alignment rack (the shop on the corner by our place). It's not the easiest car to align that is for sure.
-Ken
Old 03-26-2014, 06:00 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
What they have said above would be a good starting point, but I generally like to run a tick bit of toe out on the front of the car, say 1/16 to 1/8" total.
You need to watch the tires at Daytona...the banking can really eat them alive if you guys get to run on it for very long.
Old 03-26-2014, 06:40 PM
Bad Karma
Bad Karma's Avatar
God knows Anthony has much better answers than me (but I'll put in my two cents anyway, haha).
I will be putting back a little toe out in the front, I ran 0 at the end of last year and the car liked to wonder more at higher speeds than when I ran a little toe out, I'll be going back to it, felt more stable and had good turn in.
Old 05-05-2014, 06:40 PM
brucesallen
brucesallen's Avatar
Default dealer sayas he can't align
for track days with my Hoosier A6s, manual says 1.7 degrees F and 2.0 R. Dealer says he can't get over .5 degrees without way too much toe!! Is he wrong? I am on track Thursday.
Old 05-05-2014, 08:40 PM
blkbrd69
blkbrd69's Avatar
He is wrong.
Camber and toe are adjusted separately. Toe is done after caster and camber.
This is a good guide.
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
Old 05-05-2014, 08:56 PM
brucesallen
Originally Posted by blkbrd69
He is wrong.
But on C7 can you get 2.0 front and 1.7 in rear with only .05 degrees of toe in?
Old 05-05-2014, 08:58 PM
brucesallen
Default http://www.pfadtracing.com/blog/wp-content/uploads/2011/09/Corvette-Alignment-Guide-R
PS: I cannot get http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf to display anything.
Old 05-05-2014, 09:26 PM
05dsom
05dsom's Avatar
go to a reputable alignment shop NOT the dealer!
I used the third option on the pfadt sheet (performance street- track use with track tires) and it is a good compromise for non-track-only (DD) cars....I have sport cups
here is the Pfadt pdf file....
close - up...
Old 05-05-2014, 10:12 PM
brucesallen
Default Pfadt
Super, Thanks. Somewhat less than the owners manual says.
To Alignment suggestions??
Quick Reply: Alignment suggestions??
