Oil cooler thermostat & cooler for C6Z road course discussion
#101
I may have missed this but you are recording the oil pressure after the coolers yes?
Also, has anyone calculated the forces on the bearing at WOT @ MBT? I'd be curious if that 44psi (at the top of his temperature chart @270deg) would be enough to have no issues...
Might give me something to do today lol I'll find the ol' textbooks
#102
Have now done lots of street and track driving in hot and "cool" weather.
Improved Racing thermostat does a fantastic job of helping oil get up to operating temp.
Before on highway on a 60* day oil would sit at 145* at the tank oil temperature sender, now it is up around 180*. In a normal 15 minute street drive it is now averaging 25* warmer.
Noticed a significant pressure bump at every RPM on track using same weight 10w40 Redline oil as verified by oil analysis. Can only assume it is due to less restriction through #10 lines, Improved Racing thermostat and Setrab 172 cooler.
This Autocal EFI Live oil pressure datalog is from a 90 degree day at Sebring.
Yes pressure is recorded at stock pickup location after cooler and filter.
Yes now that logs are done I will be bumping oil weight up for hot days. My conclusion is 40 weight is just not enough for the track in Florida in the heat. Thinking 1/2 and 1/2, 40 and 50wt.?
Log photos not showing up worth a darn on a phone, so I included a smaller link that can be blown up.
You will notice pressure peaks at 5400 rpm then drops 3 to 5 psi as rpm goes up. This is something I have seen with every LS oil pump driven at crank rpm. Does not seem to matter what tank, pan, baffles, pump, oil, ext. Pressure just drops above 5400, rotor cavitation or flutter is my bet?
#103
This data logging thing can really take away your sense of security!
#104
Or maybe you guys are over thinking it. I'll ask again has anyone calculated the approx pressure needed for the bearing at those typical power levels? How about any oil analysis to see if any bearings are getting worn or if people are worrying about useless things.
#105
Really wish some engine builders would chime in to how low is to low on oil pressure, seems like the old 10psi per 1 thousand rpm is changing.
Data logging does give you too much information some times. My problem is I am 50% mechanic 50% engineer...
No freeken way could I calculate pressure actually needed. Not sure anyone could. Real world testing would provide the real answer.
Lots of guys have ran factory M1 5w30 at 300 degrees+ and survived.
#106
You are going to make me bust the textbooks out...arent you...
That rule has been around since engines have been running 20w50 as an all around engine oil lol. Says a lot I think...
Here is a quicky for how journals work:
http://www.substech.com/dokuwiki/dok...ournal_bearing
This one has some calculations for lubrication for different style of bearings (shows some maximum pressure from other engines):
http://www.substech.com/dokuwiki/dok...9ed8475a44ca2f
Classic engine oil page:
And this one is for engine bearing clearances and viscosity (would be what you are worried about with your temps and pressures):
#107
#110
Had to post a photo I took this weekend.
The new Pirelli World Challenge twin turbo Cadillac racecars of Johnny O'Connell and Andy Pilgrim are just sweet setups.
This take on cooling may drive some in a different direction. Thinking it would open up some airflow, help warmup, and make packaging easier especially for the C7Z guys having problems.
Note the large water to oil heat exchanger in the center of the photo.
Do not know who makes this one but looks something like a 18 plate C&R?
#111
Nice. Another OEM for in-line oil to water heat exchangers is Laminova. One of my friends has one on his supercharged BRZ that he tracks and likes it. Not sure if Laminova makes units that are much bigger, though.
#112
#114
Would something like the Laminova cooler put too much strain on the stock coolant/radiator? It seems like a nice, simple solution to helping the oil stay cool on track and getting it up to temp faster on the street vs a bigger cooler and thermostat. But will it actually decrease oil temps in the summer on track, and will it have a negative affect on coolant temps? My thinking has been go to the setrab and a thermostat to reduce oil temps, and hope it also helped coolant temps some so the stock radiator would be sufficient, saving the cost of the bigger radiator. The Laminova type cooler would be (or seems like it would) a pretty simple install assuming the fittings could work with stock lines for the oil and I guess adding T fittings in the coolant hoses. Anybody have a more info on these?
#115
Maybe someone else that has a C6Z will chime in......
#116
I installed a laminova on my C5 a few years back. I double passed the radiator which made packaging the laminova pretty easy. I also built a complete custom cradle for the cooling.
The things that stand out about the laminova is:
It's a modular and very easy to service/repair/modify
Lots of surface area
Very robust although a bit heavy
For me, the built in oil coolers for the corvettes are just not large enough. I have seen over 300* oil temp with them on a stock motor driven hard, but kept well under the factory redline. There is not enough room to install a adequate size oil heat exchanger in a drop in radiator for the corvette.
#117
Have now done lots of street and track driving in hot and "cool" weather. Improved Racing thermostat does a fantastic job of helping oil get up to operating temp. Before on highway on a 60* day oil would sit at 145* at the tank oil temperature sender, now it is up around 180*. In a normal 15 minute street drive it is now averaging 25* warmer.
#119
