oil pressure at idle
Just coming off several hot laps at the Glen I noticed my idling oil pressure was 15 ,oil temp of 246. Just wondering if I shpulf be looking into a better cooler?
2008 Z
Justin
2008 Z
Justin
Had the oil temp dropped at that point or was that while lapping?
The oil pressure number is fine for idle, assuming you are getting ~50+psi at high rpm.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
What weight of oil? 246 is not a bad oil temp at all.
You might want to look into something thicker if you are still running a 5w30 in the car. Maybe something in the 40w range.
FYI it takes about 7 psi of oil to float the crank off of the bearings with no load on it...so 15 is a bit on the lower side but not to the point of catching a bearing at idle.
I run 0W 40 in the summer for the track season. Mellings high vol high pressure pump for my tall CAM setup. I see 50+ at idle until hot.. THen it drops to 38-40 at idle. I see up to 60 when hot on the track... Oil temps are still too high for me (285-290) with Z51 EOC and ext Z51 cooler inline.. Like to get them down more for track days. Oil warms up quick on the street and no problem getting to 210-220 just driving normally... hmmm.
Former Vendor
Dry Sumped
on a cold start my oil pressure is around 60-65 psi
warm idle sits at 30-40 psi
on the track i have good oil pressure at high RPM 50-55 PSI
Once i get off the track and in the pits my oil pressure drops below 20 psi
It sits around 13-15 psi
If i let it cool down for a few minutes and start it back up, the oil pressure is right at 20-25 psi
Running a mechanical gauge from the oil filter assembly. So i dont know exactly how accurate it is. The car doesnt burn any oil
10qt dry sump
Never had an issue with oil pressure dropping while on track.
It only goes that low when at idle after very hot laps
After asking a few other more experienced Vette owners at the track they all agreed that this is normal, and with dry sump systems, its about were its supposed to be.
