C1265 - Is my EBCM done for?
Old 11-08-2014, 10:13 PM
stevensa
stevensa's Avatar
Default C1265 - Is my EBCM done for?
All,
While getting my car ready for next weekends track outing, my ABS/TCS lights came on and a C1265 code was reported. Looking through the FSM and on the internet, it appears that there is an internal error in my EBCM.
When I clear the code, it will sometimes take a few seconds for it to reappear. If I stab the brakes real quick during this interval the ABS will function along with the normal "ABS active."
Is there anything I can check/fix, or do I just need a replacement unit.
What causes this issue?
I have already check the power supply and 2 ground wires on the connector and they all seem fine.
Car is an 02 Z06.
Old 11-09-2014, 06:57 PM
Hi Volts Z06
Hi Volts Z06's Avatar
Had the same problem two years ago. Turned out to be a cracked negative battery terminal. Check ALL grounds again.
Old 11-09-2014, 10:20 PM
stevensa
stevensa's Avatar
Thanks for the feedback, I just checked the 2 grounds on the EBCM connector again. Both read 0.0-0.1 ohms to any ground point on the car (battery, G103, G108, engine block) with a strong signal. Both the always hot and ignition power supply terminals on the EBCM also read full battery voltage.
If there is a bad ground somewhere, it is well hidden.
Old 11-09-2014, 10:32 PM
stevensa
stevensa's Avatar
I probably should have mentioned it in my first post, but the first time that it had issues codes 1248/1255/1265 were displayed. After clearing, 1265 was the first to pop back up.
Old 11-20-2014, 07:07 PM
stevensa
stevensa's Avatar
FYI for future searchers, it ended up being the EBCM. Swapped it out with another unit and everything works again.
Old 11-20-2014, 09:36 PM
StKnoWhere
StKnoWhere's Avatar
glad you got it fixed and thanks for letting us know
Old 11-22-2014, 11:06 PM
froggy47
froggy47's Avatar
Thanks for concluding the thread.
To C1265 - Is my EBCM done for?
Quick Reply: C1265 - Is my EBCM done for?
