C6 Tow Hitch - w/ NPP exhaust?
Old 12-01-2014, 10:50 PM
jwd
jwd's Avatar
Default C6 Tow Hitch - w/ NPP exhaust?
Doing research into adding a hitch to my 2008 C6 Z51 w/ NPP exhaust.
Looks like none of the hitches on the market work w/ the NPP exhaust?
Some of the solutions posted here on the forum in the past seem less than ideal/safe (only one attachment point to cross member?)
Wondering if anyone has done deeper research into a real solution to this issue?
Old 12-02-2014, 01:39 PM
lathrash
lathrash's Avatar
I read this thinking you said tow hook, not tow hitch. Disregard my reply.
Old 12-02-2014, 02:25 PM
ErnieN85
ErnieN85's Avatar
I'm using just one attachment to the cross member. rivnut & bolt into the back. It's been all over the country with no problems.
(at least 20,000 miles of towing)
Old 12-02-2014, 02:42 PM
Dirk Miller
Dirk Miller's Avatar
Default You can do it
The Curt hitch worked for me. Code # C11380. I too did the research and was a bit hesitant until I found another memeber who said he got his to fit. Yuppers you can do it! Maybe have some bearing grease handy to help slip everything together. Oh by the way, I even had room for a Phadt tow hook to slip in there too.
Old 12-02-2014, 05:04 PM
blkbrd69
blkbrd69's Avatar
https://www.corvetteforum.com/forums...ld-photos.html
To C6 Tow Hitch - w/ NPP exhaust?
Quick Reply: C6 Tow Hitch - w/ NPP exhaust?
