Trailering a C6 GS..Need advice
Old 12-10-2014, 06:04 PM
SSWEET
SSWEET's Avatar
Default Trailering a C6 GS..Need advice
Thinking of trailering my GS south this winter. I have the use of an open trailer with an enclosed front. Will be using a Tahoe to tow the vehicle. Need advice on front tie down location on the car. Trailer has 4 shorts straps and four ratcheting tiedowns. Whats the best way to tie the vehicle down. Will it help to remove the front splitter and air dams from the car..
Thanks for any advice.
Old 12-10-2014, 08:13 PM
Scooter70
Scooter70's Avatar
Get 4 of these and use the tie down holes in the rockers.
http://www.northerntool.com/shop/too...ct_43572_43572
Old 12-11-2014, 01:25 AM
strano@stranoparts.com
Supporting Vendor
strano@stranoparts.com's Avatar
Yep, use T-hooks. I actually sell a set of Mac's straps that have them built right on the ends. It's what I use on both ends of my car. Prefer to tie the frame down than tie on the wheels. Hard on bushings and alignments that way.
Old 12-11-2014, 09:10 AM
RDnomorecobra
RDnomorecobra's Avatar
sounds like you are borrowing a trailer and straps and so don't want to buy straps. you may want to pick up straps that can just go through the wheel or around lower control arm ... ie. http://www.easternwreckerstore.com/A...gs-p/38-50.htm
Old 12-11-2014, 11:48 AM
Supporting Vendor
That's really not a great idea. And he doesn't have to buy straps, he can buy the t-hooks that will clip into the hook on the end of a normal tow-strap.
But I do caution you to be aware that not all straps are good enough. Many use way too light duty tie-downs. They think that if it's rated at 3000 pound, or even 1500 (yes I've seen that) that x4 it's plenty. It's not. Think about the energy involved if you happen to have an accident. I've seen a corvette come off a trailer due to insufficient straps. And remember in an accident if you happen to hit something head on, only the rear straps hold the weight of the car.
I only use 10k rated, 3333 lb working load rated straps for my car. I tow, a lot. If you plan on towing much, get good straps.
Old 12-11-2014, 04:27 PM
rbl
rbl's Avatar
I have a set of the hooks (best way to go for sure) and maybe the straps too. I used them on my C6 and towed it a LOT on my 18' open trailer to the track.
I think mine have the swivel link as well ... have to check on that.
Sell very reasonable .... PM if you want them.
Old 12-11-2014, 04:51 PM
RDnomorecobra
I use t-hooks myself and by the way, was not suggesting he use straps that are not rated for the load he is carrying. The link was just an example.
Old 12-11-2014, 06:15 PM
SSWEET
SSWEET's Avatar
Thanks everyone for the info.....going with the t hooks...gotta check on the straps for load limits.
Old 12-11-2014, 08:48 PM
BlueAngelSAE
Support Corvetteforum!
BlueAngelSAE's Avatar
I use t hooks and cross strap
Old 12-11-2014, 10:19 PM
SSWEET
SSWEET's Avatar
Attachment 47847410
I think your setup is what I'm going to use...is there only one way for the t hook to go in to the frame slot?
Old 12-12-2014, 04:14 AM
BlueAngelSAE
yes the t hooks go in and then rotate them 90 degrees. I bought mine and a spare at Northern tool and added small Clevis's to them that I picked up at Home Depot. I think I got the straps at one of those places as well. The straps clear the stock splitter so no need to remove it. I leave the car out of gear and release the e brake while its strapped down.
Old 12-12-2014, 11:47 AM
Iconic
Miller Time Wisconsin 🍺
Iconic's Avatar
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes on 940 Posts
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Where have I seen that carbon flash GS before?
Another vote for the T hooks with nylon straps X pattern
Old 12-12-2014, 12:56 PM
BlueAngelSAE
Originally Posted by US Icon
Where have I seen that carbon flash GS before? Another vote for the T hooks with nylon straps X pattern
not sure, been too busy working, instead of hitting the track since our spring FL 3 track attack
Old 12-12-2014, 02:59 PM
JerryTX
JerryTX's Avatar
WHOA! I wanna see pics of the RAMPS you use!! Seriously, how do you get it off of there?
Old 12-12-2014, 04:11 PM
BlueAngelSAE
He jumped it, I was there to watch it and these corvettes are crazy solid!!!! Ok he used a flatbed tow truck!!!
Old 12-12-2014, 04:26 PM
JerryTX
JerryTX's Avatar
That's cheating!
Old 12-12-2014, 04:27 PM
Iconic
Iconic's Avatar
I have hired rollbacks. They back up to my trailer, I drive the Vette on, they pull ahead, tilts the bed, I drive it off.
Here it is new at the dealer, 2 miles on the clock.
To Trailering a C6 GS..Need advice
Quick Reply: Trailering a C6 GS..Need advice
